Oil pressure and oil pump - NCRS Discussion Boards
  • Donald H.
    • November 2, 2009
    • 2586
    I have my engine out due to frame off restoration and getting ready to replace the oil pump. My car is a small block L79 66. I've owned the car about 3 years and the engine had a fairly recent rebuild when I purchased it. However the re-builder install a M55HV and my pressure was running very high. Someone also put in an 80 lb gauge, so that's something else I will correct.
    I have purchased a Melling 10553 pump and install the green 49# spring.
    I was talking to a friend who is a very good engine builder and he says the pump should have the 60# spring and thus relief pressure of 60#. He says he has GM documentation to back this up and that the 49# spring is wrong.
    From my research on this forum, what I think is correct is that some (or all starting sometime in the 63 model year), solid lifter small block cars with 80# pressure gauges used a pump with the 60# relief. However, the hydraulic lifter small blocks used a 45# relief pump and have a 60# pressure gauge.
    Is this correct? And is there GM documentation that confirms this?
    Don Harris
    Former: 60 Red/Red, 2x4, 245hp (Regional and National Top Flight 2013), 66 coupe Nassau Blue, L79 (Chapter and Regional Top Flight 2017)
    • 15706
    Re: Oil pressure and oil pump
    Basically correct, and you can verify in the AMA specs for your year and engine option. The actual hot oil pressure spec is 30-45 @ 1500, so even the green spring will likely be too high.
    Don't forget to correct your buddy so he doesn't screw up a bunch of engine rebuilds in the future. Show him the AMA specs and ask him to show you the documentation he claims states 60 psi.
    Mechanical lifter 327s small got a 55-60 psi relief spring in the standard volume pump and an 80 psi dash gage from very late '63 production through '65.
    • Donald H.
      • November 2, 2009
      • 2586
      Thanks Duke.
      I'll get the AMA specs and have them handy.
      Don
      Don Harris
