75 hardtop - NCRS Discussion Boards
75 hardtop
  • Ross F.
    • August 31, 2004
    • 167
    75 hardtop
    I have a 75 roadster. I'm thinking of getting a date correct hardtop for it. I've noticed that it already has the threaded ferrules in the deck lid for the side bolts. But it does not have the third rear mounting hole in the deck. Did all roadsters come this way?
    Does this mean it did or didn't come with a hardtop? I have the tank sticker, but I can't see C07 on it. But I can't see much on it as it is really faded.
    • 43246
    Re: 75 hardtop
    Ross------
    The center hole was only drilled if the car was originally equipped with the optional C-07 hard-top. The fact that your car does not have the hole is proof that it was not delivered with the C-07 option.
    • Ross F.
      • August 31, 2004
      • 167
      Re: 75 hardtop
      Thanks Joe. That's what I thought. I was just confused by the side bolt mountings that are installed on my deck lid. I guess all roadsters must come with those . I read somewhere that, instead of the rear bolts, I could use the soft top barbed studs in the hardtop and mount it basically like a soft top. Is that true?
        • 43246
        Re: 75 hardtop
        Ross------
        Yes, I believe that all 68-75 convertibles had the mounting nuts on the sides of the deck lid, whether or not the car was originally equipped with a hard top.
        The barbed studs were used for the rear mounting points for hardtops during the 1968 model year. I suppose they could also be used for 1975. Would I use them? Not a chance. The studs with special washers and nuts are WAY better and more secure. GM didn't abandon the use of the barbed studs after 1968 because they worked as good or better than the conventional studs.
        Also, you don't absolutely need to use the center rear hard-top mounting point if you'd rather not drill the deck lid. 1968-69 did not use the center mounting point. Of course, GM did not add the center mount point because it worked just as well without it but I never experienced any problems with my 1969 which doesn't have it.
        • Don L.
          • August 31, 2005
          • 1005
          Re: 75 hardtop
          Ross------
          Are we sure about this? I thought for sure I've seen soft-top-only cars without the side mounting hardware...
          Don Lowe
          NCRS #44382
          Carolinas Chapter
            • 43246
            Re: 75 hardtop
            Don-------
            No, I'm not sure about this. That's why I used the term "I believe". Anybody out there have a non-C-07 convertible with or without the special nuts?
            • Don L.
              • August 31, 2005
              • 1005
              Re: 75 hardtop
              Hi Joe. Perhaps a poor choice of words in my reply. I really think that only hard top equipped cars had mounting hardware, but I'm not 100% certain, especially when you say you believe all cars had the hardware. I know you know a lot about these things and respect your knowledge, therefore, my soft challenge earlier.
              Let's see what other say about the hardware.
              Don Lowe
              NCRS #44382
              Carolinas Chapter
              • Ross F.
                • August 31, 2004
                • 167
                Re: 75 hardtop
                My wife says I'm a "special kind of nuts"
                Like I said originally, I have no center hole, nor do I have any documentation that my car ever was equipped with a hardtop.
                But I definitely have the special nuts mounted in the edges of the deck.
                Now, I have no idea what a previous owner may have done, or even if the deck lid is original.
                The car looks like it's been painted at least once. But I do not see any sign of someone filling in the center mounting hole.
                • Edward B.
                  • March 29, 2013
                  • 691
                  Re: 75 hardtop
                  I can add to the thread, but the AIM really isn't that helpful with the location! Can someone post a picture showing where to look and exactly what I'm looking for with regards to the side mounts?
                  Ed
                    • 43246
                    Re: 75 hardtop
                    Ed
                    Ed-------
                    Not the best pictures, but this illustrates the location of the side mount special nuts.
                    • Edward B.
                      • March 29, 2013
                      • 691
                      Re: 75 hardtop
                      Well, I don't see anything at all there, so I'm not sure if my contribution will help (see the attached pictures).
                      But anyway, the car was assembled on October 21st, 1969 and as far as I know, only came with the soft top.
                      Ed
                        • 43246
                        Re: 75 hardtop
                        Ed
                        Ed--------
                        I don't see the "wings" of the deck lid in these photos.
                        • Edward B.
                          • March 29, 2013
                          • 691
                          Re: 75 hardtop
                          OH!!! they're on the DECK LID! I thought they were on the body itself.
                          Here's the pictures (not great, but they should give you the idea), and you can see there's nothing there. Not even any pre-drilled holes. I also checked the inside for filler and found nothing so it looks like my deck lid didn't have the nuts, or even the holes to put them in. And by the way, no center deck lid hole either.
                          Ed
                            • 43246
                            Re: 75 hardtop
                            Here's an interesting thing:
                            The installation of the CENTER hold-down is shown in the C-07 section of the AIM. This page shows the size of the hole in the deck lid and implies that the hole is to be drilled at St. Louis.
                            The installation of the SIDE MOUNT special nuts is also shown in the C-07 section of the AIM. However, there is no reference as to the size of the hole or instruction that it be drilled.
                            • Edward B.
                              • March 29, 2013
                              • 691
                              Re: 75 hardtop
                              Which indicates that the holes should already be there by the time the car comes down the line!
                              Ed
