I was looking to get some thoughts/opinions of authenticity of this stamp pad. Thank you.
Engine Stamp Pad
Tags: None
- Top
Re: Engine Stamp Pad
The VIN characters are the wrong size and width, and they look like they were not stamped in a gang holder. The Flint characters are better. The grain looks like it was applied with an electric sander and it is not completely straight. The pad is definitely not original.- Top
The vin stamp looks to small as Pat says, flint stamp I think is okay and the broach may just be someone had the cylinder head off and maybe some sanding marks??New England chapter member, 63 Convert. 327/340- Chapter/Regional/national Top Flight, 72 coupe- chapter and regional Top Flight.- Top
What I get from the judging manual is the VIN derivative stamping started in 1960 with VIN 1800. And the VIN derivative was applied WITHOUT a gang stamp from VIN 1800 thru 5394. Characters were 3/16th inch from 1800 thru 5394. 5395 and beyond went to 5/32 characters. I am no expert on this stuff, but that photo does not seem to correlate with the words in the judging manual.Last edited by Terry K.; July 30, 2015, 05:38 AM.- Top
The description of the stamping is correct but the VIN numbers are wrong. I have pictures of original pads as early as #1332 and as late as #5884 that are stamped freehand in the larger characters.What I get from the judging manual is the VIN derivative stamping started in 1960 with VIN 1800. And the VIN derivative was applied WITHOUT a gang stamp from VIN 1800 thru 5394. Characters were 3/16th inch from 1800 thru 5394. 5395 and beyond went to 5/32 characters. I am no expert on this stuff, but that photo does not seem to correlate with the words in the judging manual.- Top
