Bleeding Issue with Front Caliper - NCRS Discussion Boards
+ More Options
Posts
  • Christopher R.
    • April 30, 2013
    • 65
    I have another thread open about the lights on my 72. I am also having an issue with the front caliper not getting any fluid into it. All the other calipers have been bled its only the front drivers side that is not getting fluid. We know that the proportioning valve is not set right so we are going to fix it. We are also going to change the master cylinder to a replacement which has the bleeder valves on it. Does anyone have any advice as to anything else that should be addressed or anything else that we should check for. This seems to be the only solution to us right now.
  • Bill C.
    • July 15, 2007
    • 904
    Re: Bleeding Issue with Front Caliper
    collapsed rubber brake line.
    or rusted bleeder hole
    • Christopher R.
      • April 30, 2013
      • 65
      Everything is brand new. There is fluid going into the line but once it gets to the caliper it wont go through.
        • 11653
        Obstructed bleeder or obstructed crossover.
        If you remove the bleeder and no fluid comes out, then you may have to remove the caliper and find the problem.
        • Gene M.
          • April 1, 1985
          • 4232
          No cross over on the left front. It has a 4 inch line direct out of the brass block if it is anything like my '68.
          Suggestion to remove bleeder screw is by far the easiest. It's easy to disconnect the steel line at the frame to see if fluid comes out also. More like a bad caliper or plugged rubber line if nothing comes out bleeder.
            • 43242
            Patrick and Christopher------
            YUP.
              • 6948
              Chris, Is it possible there may have been a piece of a plastic cap or rubber plug blocking the hole where the rubber hose fitting goes into caliper? I cannot imagine that something is up with caliper other than a obstruction somewhere.
              • Christopher R.
                • April 30, 2013
                • 65
                Issue resolved. Muskegon sent me a replacement caliper and we pressure bled the system using a tool from Amazon.com what worked perfectly. no issues with the brake light on the dash and the brakes are perfect. Pressure bleeding is the way to go.
                  • 43242
                  Christopher------
                  Was the tool the Motive Products pressure bleeder?
                  • Gene M.
                    • April 1, 1985
                    • 4232
                    Should not have to pressure bleed. Gravity bleed should get a steady dribble out the bleeder screw. It sounds like you had a something bad with the caliper. The pressure bleed had nothing to do with the solution.
                    • Christopher R.
                      • April 30, 2013
                      • 65
                      Yes, it was the motive bleeder system. Here is the trick though. You follow the instructions exactly and pump it up to 15 pounds and the brakes bleed perfectly and the brake switch stays in place - perfect. The problem is that the tool comes with these cheap clamps so please run out to Harbor Freight and get two 6 inch C Clamps and you are good to go. One of the best investments I have made and solved weeks of problems in one afternoon.
                      • Gene M.
                        • April 1, 1985
                        • 4232
                        Christopher, there is no trick to bleeding brakes, pedal press and release will get the job done. You were good on three of the four calipers and once you "corrected" the bad one everything bleed out fine. Believe me the pressure system was not the correction factor.
                        • Gary V.
                          • April 15, 2012
                          • 76
                          I agree with Gene. I always had success bleeding the calipers using the brake pedal press and release outlined in the Corvette repair shop manual.
                          • Frank K.
                            • January 1, 2000
                            • 319
                            I had the same problem. It was a the caliper rubber hose. when I suspected it I pulled off and blew air through it. It blew fine . Placed on car, caliper was not getting fluid. Removed and installed a ss hose and everything was fine.
                            • Thad L.
                              • April 30, 1999
                              • 168
                              Christopher that is my technique exactly. Been doing it for over12 years!!
                              Thad
