Another "why doesn't my brake lights and turn signal/hazard lights work" question - NCRS Discussion Boards
  • Christopher R.
    • April 30, 2013
    • 65
    I have seen as many responses to this age old Corvette question but I have tried everything with no good results. I have a restored 1972 Corvette and all of the wiring has been replaced with complete harnesses from Lectric Limited. I have Headlights and taillights working, the factory alarm is hooked up and it works perfectly. My issue is that the other lights do not work. I have replaced the brake light switch, I have replaced the Turn Signal Switch - the horn works, even the Key buzzer works but no brake lights or turn signals/flashers. I have tried to trouble shoot the system but I am out of ideas
    Please help!!!!!
  • James B.
    • March 1, 1985
    • 217
    Re: Another "why doesn't my brake lights and turn signal/hazard lights work" question
    Check your hazard flasher switch.
    • Christopher R.
      • April 30, 2013
      • 65
      Thanks. Do you mean the turn signal switch? or the actual flashers? is there a difference between turn signal flashers and hazard flashers?
      • Christopher R.
        • April 30, 2013
        • 65
        Ok, replaced the switch and the fuses and now the turn signals work perfectly, but the hazards come on but don't blink - any idea what causes that?
        • Russ S.
          • April 30, 1982
          • 2163
          Check the hazard flasher. I believe it is in the jack compartment.
            • 15616
            Actually the Hazard Flkasher is in the fuse box by the hood release.
            The flasher int he jack compartment is for the alarm system (ISE)
            • Christopher R.
              • April 30, 2013
              • 65
              ok i will recheck that tonight thanks!
              • Russ S.
                • April 30, 1982
                • 2163
                Thanks for the correction/info Terry.
                  • 15616
                  I should have said the Hazzard Flasher is in the fuse panel by the hood release. There is no fuse box.
                  • Christopher R.
                    • April 30, 2013
                    • 65
                    Problem solved by going out and getting a #536 flasher, which was not easy to get, and it worked. Thanks for all the recommendations.
