C2 Heater box gaskets - NCRS Discussion Boards
  • Donald H.
    • November 2, 2009
    • 2580
    I just finished restoring my heater box. I'm trying to make sure to locate the gaskets correctly when I but it back together.
    In the attached picture there are three gaskets (from the Dr. Rebuilt kit). I think I have them in the correct order per the AIM UPC 1 ASM sheet D6. I believe the gray gasket is listed in the AIM as item 2 INSULATOR and it goes between the inner heater box and the heater core/bracket.
    Can someone confirm this?
    Don
    Don Harris
    Former: 60 Red/Red, 2x4, 245hp (Regional and National Top Flight 2013), 66 coupe Nassau Blue, L79 (Chapter and Regional Top Flight 2017)
  • Donald H.
    • November 2, 2009
    • 2580
    Re: C2 Heater box gaskets
    By the way, I found the attached pictured lighter rattling around inside the inner heater box. Looks like something that would have been there since the late 60s or early 70s, and it still strikes a spark!!
    Don
    Don Harris
      • 6940
      Don, It looks like you have everything correct as far as the gaskets go. Lighter is a neat item. good keep sake.
      • Patrick B.
        • August 31, 1985
        • 1992
        The illustration on the DR. Rebuild web site is confusing since it shows both the grey gasket and the black gasket on the outside of the heater core mounting plate rather than the more logical way you have them. Don, I will keep in touch with you about how your's fit before I re-install my heater at Zane Finney's shop.
        • Donald H.
          • November 2, 2009
          • 2580
          Thanks all
          Don Harris
          • Donald H.
            • November 2, 2009
            • 2580
            Sounds good Pat. By the way, I used your technique to test the new heater core.
            Don
            Don Harris
            • Richard M.
              Super Moderator
              • August 31, 1988
              • 11318
              Don/Pat, This has always been confusing to me also, but here is my thought on this mystery foam seal....
              The AIM is a bit confusing but I'm not sure that yours is correct. I looked at the DR diagram and it doesn't match the AIM.
              Below is a AIM copy with notes that Zip uses. There it shows the profile of the light foam seal. You can see the profile at the top right and bottom right in the picture. The AIM also specifies a adhesive(55A 1.5 oz) to attach it to the housing, which appears to be on the backside. That's a substantial amount of glue so I think the foam gets glued on the backside around the perimeter of the housing before installation.
              Also, the heater box came as a assembly. The foam seal, Item 2 "INSULATOR"(light foam), and Item 5 "SEAL"(dense foam) are shown as separate parts. IMO, if the INSULATOR was put on over the 4 studs first I think it would not need adhesive either.
              I used the Zip Products ZWS-478 kit just the other day on a '67 heater box rebuild. Some pics in this post.
              Note the foam seal is carved to fit over the edge of the housing and I believe it is positioned on the backside of the box after installation to the firewall. This profile matches the AIM more accurately. I don't think that light foam seal should have holes in it for the studs to pass through. This is also shown in the AIM.
              Also, if the core frame was placed over the foam as you show in your diagram, the inner side would have a large gap where it meets.
              Unless there's a error in the AIM, or I've missed something obvious, this is how I feel it's assembled.
              Rich
              p.s. I also found a lighter in my '59 when I bought it 29 years ago. But it was tucked in the hole under the sill step. That along with a few other trinkets.
              • Patrick B.
                • August 31, 1985
                • 1992
                Richard/Don
                I don't have my Paragon heater gasket kit at home but I will check it out later this week at my shop. I think it is carved out like Richard's without any stud holes. The AIM picture was confusing to me, but Richard's explanation makes sense. Don, I think the way your picture shows the gaskets, the gray seal will prevent the heater core mounting plate from fitting inside the heater housing correctly.
                • Timothy B.
                  • April 30, 1983
                  • 5179
                  Richard,
                  I agree with your assessment of this foam seal. On my 63 I installed it as you describe, maybe others that have done this can respond.
                  • Donald H.
                    • November 2, 2009
                    • 2580
                    OK, I see how it goes now. Hard to understand from the AIM. So the core is mounted to the inside box, then the box to the fan unit through the firewall. the gray foam insulator seals the inner heater box flange to the firewall. Now that makes sense!!!!
                    Zip sells the gray foam insulator as a individual piece, so I just ordered one.
                    By the way, this all begs another question. On reassembly can the inner heater box be installed before the jute firewall insulation and the firewall mat? What is the best order of assembly?
                    Don
                    Don Harris
                    • Bill W.
                      • March 1, 1980
                      • 2000
                      Rich & don I dont want to hijack your thread but I found two Hypo .needles and syringes in my windshield washer bottle on my 62 and lots of sockets in the trunk body mount holes (and they had the covers on them ).
                      • Richard M.
                        Super Moderator
                        • August 31, 1988
                        • 11318
                        Don, I always install the ceiling insulation, then the pedal support, then the firewall insulation, then the heater box lastly. However, if the wiper motor is out better to install that before the heater but it can go in later.
                        I did this colorized diagram early this morning depicting the way I think the seals were intended from the AIM, but it's hard to read. If you download it you may be able to mag it. I'll play with it tonight or tomorrow to make it bigger.
                        Rich
                        • Donald H.
                          • November 2, 2009
                          • 2580
                          I hope you carefully disposed of the hype needles and syringes!!!
                          Don
                          Don Harris
                          • Donald H.
                            • November 2, 2009
                            • 2580
                            Rich
                            [ATTACH=CONFIG]62492[/ATTACH]
                            Your enhancement makes it much easier to see.
                            Don
                            Don Harris
                            • Hank D.
                              • January 1, 1999
                              • 137
                              [ATTACH=CONFIG]62485[/ATTACH]
                              [ATTACH=CONFIG]62484[/ATTACH]
                              Rich
                              [ATTACH=CONFIG]62486[/ATTACH][ATTACH=CONFIG]62487[/ATTACH][ATTACH=CONFIG]62488[/ATTACH][ATTACH=CONFIG]62489[/ATTACH]
                              I agree with the explanation Richard provides in Post #7 above for the following reasons:
                              1. The AIM diagram does appear to show the "insulator" behind the firewall, and on top of the heater box.
                              2. if this were a "gasket", it seems it would be made to form a complete seal instead of made C-shaped.
                              3. GM would not call out cement if it were not needed, and it appears it would not be needed
                              if this were a "gasket", installed between the heater box and the firewall.
                              4. The AIM says use "1.5 oz per job (of cement), insulator to heater" in 3A, Section 1, Sheet B 5.00, not insulator to firewall.
                              Then again, I could be wrong.
