'66 L79: What are common head marks for fan clutch to water pump bolts - NCRS Discussion Boards
  • Gary B.
    • January 31, 1997
    • 6994
    The '66 TIM&JG spells out the grade 8 cad/zinc feature of the fan clutch to water pump bolts for '66, but it makes no mention of typical head marks. Does anyone know what head marks have been observed on Bowtie 66s?
    Gary
  • Henry J.
    • October 31, 1999
    • 457
    Re: '66 L79: What are common head marks for fan clutch to water pump bolts
    Gary:
    I can tell you this: at this location on my 66 L79, I have one bolt with an L8 headmark and 3 bolts with an S headmark. All these bolts are Grade 8.
    • Kenneth F.
      • September 30, 1988
      • 282
      Gary, My L-79 had a warranty pump installed in 1967. I cannot be certain the original bolts were re-used. The 2 on the driver side have an M with 3 lines radiating from the letter. Top bolt on the passenger side is a TR with 3 lines radiating from the letter. Bottom bolt looks like an O with 3 lines radiating from the letter.
      Ken
      • Kenneth F.
        • 282
        Gary, The fan clutch bolts are all grade 8. There is a small marking at the center of the bolt head. I can remove a bolt to better read the marking if you need more information.
        The VIN is 11,xxx
        Ken
        • Gene M.
          • March 31, 1985
          • 4232
          If I'm recalling correctly I think it is "AS" head mark and grade 8 fine thread.
          • Michael M.
            • January 31, 1993
            • 603
            My 1966 L-79 has SBC with six radial lines as a head marking grade 8 fine thread.
            • Jeremy R.
              • May 23, 2012
              • 137
              My 66 L-79 bolts have the headmark AS and the grade 8 lines
              • Gary B.
                • January 31, 1997
                • 6994
                Thanks all. It looks like there are several options of head marks.
                Gary
