What is the connecting piece of a gas cap called? - NCRS Discussion Boards
  • Bob B.
    • March 1, 2003
    • 831
    Hi all,
    Can anyone tell me what the piece on the bottom of a gas cap that connects to the fill pipe is called?
    Bob
  • Joe R.
    • July 31, 1976
    • 4551
    Re: What is the connecting piece of a gas cap called?
    How about some more detail or a pic?
    JR
    • Bob B.
      • March 1, 2003
      • 831
      JR,
      When you put a gas cap onto a C1/C2/C3 fill pipe, there is a piece on the underside of the gas cap that has two ears on it that go into the fill pipe. The fill pipe has two slots in it that the ears in the piece on the underside of the gas cap go past. Once the cap is seated, you turn the cap and the ears turn away from the slots in the top of the fill pipe and then the cap stays on until you reverse the process.
      So, does anyone know what the piece with ears on it on the underside of a gas cap is called??
      Bob
      • Paul D.
        • September 30, 1996
        • 491
        I am not sure it would have a proper name or component designation as I believe it to be part of the gas cap and not / never was available separately. Chip.
        • Joe R.
          • July 31, 1976
          • 4551
          I believe the C1 has the ears on the inside and the C2-C3 is on the outside of the tube but I would also call it the "Gas Cap" "Thingy".
          JR
          • Bob M.
            • March 1, 2004
            • 66
            Bob,
            How about C-1 gas cap inner lock, but I like "Thingy" better.
            • Ed S.
              • August 6, 2014
              • 1377
              "Framus" - its a framus. Had to have one replaced once on a 68 Plymouth I had years ago. Very expensive, took a couple of days at the dealership.
              Ed
              • Ed S.
                • August 6, 2014
                • 1377
                Jim,
                Sorry for the joke reply. I got to thinking about your question and began to search (Google) different terms, if you search for "gas cap ears" - then select image view you will get a lot of pics of the back side of traditional (vintage) gas caps with the two protrusions that fit into the cut outs in the gas filler tube flange and tighten when the cap is twisted. I've attached a (random) pick of a cap showing the "ears".
                Also, I found the text from the 1968-1982 Corvette Restoration Guide by Richard Prince. On page 70 he talks about gas caps and mentions "ears" that secure the cap to the tank neck.
                So..... it appears that the commonly accepted term or word for what you are describing is (are) "ears".
                Ed
                • Keith R.
                  • August 31, 2001
                  • 660
                  Ask Joe Perri. I believe that he rebuilds them.
                  Keith MacRae
                  NCRS #36692
                  New Mexico Chapter
                  1960 290HP FI
                  2013 427 Convertible
                  Shade tree mechanic and
                  B-52 pilot extraordinaire
                  • Roger W.
                    • January 29, 2008
                    • 569
                    I think that you mean the gas filler neck. Look on page 78 of the Corvette Central Catalog.
