63 radiator petcock question - NCRS Discussion Boards
    • 6960
    I have a petcock that has aluminum threads on the part that screws into the radiator and metal on the winged ends, is the correct petcock suppose to be all aluminum? during my last judging this was brought to my attention, that its should be all aluminum and not magnetic.
    • 11698
    Re: 63 radiator petcock question
    Ed,
    If 63 is like later years then from the factory they had an aluminum plug that was screwed into the hole, very similar to the drain plugs in the side of the block. In service this was then usually changed to the petcock. So, in theory any petcock would not be correct.
    If you need an all-aluminum one, Paragon reproduces it.
    https://www.paragoncorvette.com/p-35...-assembly.aspx
    Patrick
    • Joe R.
      • July 31, 1976
      • 4552
      Ed,
      The judges are correct in that a 63 should have an all aluminum petcock. They were supplied with the radiator from Harrison. Even the replacement radiators were supplied with an aluminum petcock.
      JR
      • Mike M.
        • May 31, 1974
        • 8409
        Agree with joe. C2 petcocks were utilized, not a plug. Mike
          • 11698
          There you go. Aluminum petcock in 63, but your 72 would have been a plug.
          • Mike M.
            • May 31, 1974
            • 8409
            Not seen a plug on any c2 sbcs. Mike
              • 11698
              I saw one not long ago on a C3. As you might expect they're not common this many years later.
                • 6960
                Thanks everyone for your reply's, I will try and see if DeWitt's has the all aluminum petcock when I am in Carlisle next month.
                • Harry S.
                  • July 31, 2002
                  • 5349
                  Ed, I just ordered one from them. It was $10 and that included shipping. I had it in a few days. Order two and have a backup.
                    • 6960
                    Harry, did you use DeWitt's ?
                    • Harry S.
                      • July 31, 2002
                      • 5349
                      Yes...............
                        • 6960
                        Thanks, Are you at the national meet ?
                        • Harry S.
                          • July 31, 2002
                          • 5349
                          Yes, check the pictures posted by Vinnie Peters
                            Here's what the aluminum petcock looks like.
                              • 6960
                              I wanted to bring this thread back to the front so someone could see a post on this discussion.
