For C2 to C3 and beyond, I will submit that the appropriate driven gear with the correct colored plastic/tooth count was installed on the engine dress line, at St. Louis. It would not have been feasible to stock 3 different M21 trannys (as an example); for low numerical economy axles (3.08, 3.36, 3.55), and two for the performance-lite axles (3.70 and 4.11). Only 4.56 was available in the all-out set-up, so that particular driven gear [steel] could either be installed at Muncie or St.Louis.
Stocking only 4-speeds with 3 different trans drive gears would simplify inventory. The Chevy parts catalogs (P&A30) [ie. service] seem to show only 3 versions available for M21 and M22, although they make proper selection much more difficult than necessary.
M20 close ratios are simpler, as no 3.70-up axles were factory-available.
So what do the experts say ?
