Hardtop Side Mount Washers - NCRS Discussion Boards
  • Ralph B.
    • July 30, 2008
    • 178
    Can I assume that the 2 rubber washers that are used on the side mounting assembly are a different size than the 2 rubber washers used for the rear deck mounting assembly which are the washers that are to be kept in the cloth bag when the hardtop is in place.
    if this is the case, could anyone tell me what the OD of those washers are (ones used on the side mount)?
    Thank you,
    Ralph
    Re: Hardtop Side Mount Washers
    Thank you,
    Ralph
    Ralph -
    There were no rubber washers used on the forward/side hardtop attaching bolts - just the bolts.
    • Kim C.
      there are 3 different size rubber washers
      1 pair for the rear bezel on deck
      1 pair for the rear bolt on deck (these are the smallest , and go in the cloth bag)
      1 pair behind the side mount retainer for hard top - (not for the bolt)
      ( i don't have the sizes here)
