P headmark bolts - NCRS Discussion Boards
P headmark bolts
  • Henry J.
    • November 1, 1999
    • 457
    P headmark bolts
    Were bolts with a simple P headmark used on Corvettes? I don't recall seeing many (any?) references to P headmark bolts in my 66 & 68 TIM&JG's, but I do have some of these bolts in my stash of fasteners.
    I assume the P identifies the manufacturer. Is it known what company that would have been?
    • 15625
    Re: P headmark bolts
    I don't know for sure, but I suspect Phoel Manufacturing in Chicago/Cicero IL. I used to inspect their electrical facilities in my youth. As far as I know they went out of business in the early 1970s. At least they went out of business at their location on Roosevelt Rd & Central Ave.
    • Tony S.
      NCRS Vice President, Director Region VII & 10
      • April 30, 1981
      • 992
      I found several cad bolts with a simple P on my 1953 Chevy 5 window pickup truck, so they were in use by Chevy long before 68-69. Although I've never seen a P head mark on a C2.
      Region VII Director (serving members in Arkansas, Kansas, Louisiana, Missouri, Oklahoma and Texas).
      Original member of the Kansas City Chapter, est'd 07/11/1982.
      Member: 1965 and 1966 National Judging Teams
      Judging Chairman--Kansas City Chapter.
      Co-Editor of the 1965 TIM and JG, 6th and 7th editions.
      • Henry J.
        • November 1, 1999
        • 457
        Thank you, Terry.
        I will up-date my list of fastener manufacturers accordingly and look upon my P bolts now with far less suspicion.
        • Henry J.
          • November 1, 1999
          • 457
          Tony:
          On my 66, the two bolts holding the licence plate bracket to the center crossbar are grade 5 P bolts. At the moment, I am not certain of their length.
          The AIM calls these bolts out as being GM#180018. I can find no specifications for these bolts using that number.
          • Gary C.
            Administrator
            • October 1, 1982
            • 17866
            Henry,
            IIRC I previously posted the 1964 Industrial Fastener Institute logos. This lists all the Fastener marks that are trademarked with and listed with the IFI in 1964.
            Per that document, the plain P logo belonged to Prestole Fasteners. You can Google Prestole Fasteners and there's a zillion hits.
            Gary
            NCRS Texas Chapter
            https://www.ncrstexas.org/
            • Henry J.
              • November 1, 1999
              • 457
              Gary:
              Thank you for the clarification.
              I can't believe I missed your post but my mind isn't what it once was.
              • Peter H.
                • April 1, 1980
                • 228
                HENRY I HAVE BEEN BUYING " P " MARKED BOLTS FROM A COMPANY CALLED " H PAULIN & COMPANY LIMITED "OUT OF TORONTO ...PETER ...
                • Henry J.
                  • November 1, 1999
                  • 457
                  Thank you, Peter. I will check this out.
                  • Peter S.
                    • March 28, 2012
                    • 327
                    Tony:
                    Hi Henry,
                    I find multiple references to that part number, one being Paragon, the other being the AMK product catelog. Both list this as a Grade 5 bolt with "TR" head markings. Paragon lists this for a Front License Plate Bracket Bolt for '63-'67.
                    • Rich P.
                      • January 12, 2009
                      • 1361
                      Boy P headmarking bolts were found through out. Just a sample, 69 grill support bolts, 63-7 License bolts, Various engine brackets 7/16" hex VC bolts. Thermostat housing, I can go on and on but the key is to find the original style font used!!!
                      • Henry J.
                        • November 1, 1999
                        • 457
                        Thanks, Peter. I had checked out the AMK Products information to confirm the GM #180018 bolt size.
                        • Henry J.
                          • November 1, 1999
                          • 457
                          That's comforting information, Rich. I was worried that I may have nothing more in my stash than hardware store bolts. Now I don't think so.
                          • Jim S.
                            • March 1, 1986
                            • 1408
                            If memory servers correctly , weren't P bolts also used on some 60's alternators , holding the two case halves together ?
