1966 Corvette, Center Console, Black Touch-Up Paint - NCRS Discussion Boards
  • Edmund C.
    • April 14, 2015
    • 232
    Brothers: Can anyone tell me where I can get some black touch-up paint to match and touch-up some small specks on my center console? Many thanks. Best regards, EWC
  • Jim S.
    • March 1, 1986
    • 1402
    Re: 1966 Corvette, Center Console, Black Touch-Up Paint
    Edmond,
    I think the general consensus is that Krylon semi flat black #1613 , is a pretty close match to the original black color on the console .
    That being said however , I don't know how well it will blend in on a touch-up situation ?
    Jim
    • Frank D.
      • December 27, 2007
      • 2703
      If the console (I have a '63 so I don't know) is the same "camera case" black used on the instrument cluster then I've used this successfully.
      Just dab a bit on the bare spot ... let it dry for a few seconds and just tap it with a fingertip to dull it just a tad. Sounds sorta silly but it works on the cluster... I did a large repair and brought the one-year-only '63 cluster back to life...
      • Edmund C.
        • April 14, 2015
        • 232
        Thanks fellows. Much obliged.
        • Rob M.
          • April 30, 2003
          • 657
          Edmund,
          Many (including myself) have used SEM 39143 with success. You might want to give it a try.
          Good luck
          Rob
          '66 327/300 Regional Top Flt
          '08 6 speed coupe
          • Georges C.
            • June 17, 2013
            • 72
            For spots I often use a tooth pick dabbed in the paint and/or q-tip for spots. Have used Krylon and long time ago Uticolor.
