69 inner fender hole patching - NCRS Discussion Boards
  • Richard R.
    • January 5, 2010
    • 270
    having been blessed by a previous owner or mechanic that didn't like staples or rivets, I have to fill in some holes in the inner fender wells of my 69 L46, before applying blackout etc. most of these holes are 3/16 to 1/4 in size. some will be covered by other parts, like skirting/rubber seals, while others will be out there for all to see. I think I can paint over most of them but a couple will be exposed. What type/color/brand of filler/fiberglass do you suggest using on these to match?
    Rich
  • Mark E.
    • April 1, 1993
    • 4600
    Re: 69 inner fender hole patching
    I've had good results repairing my car's inner fenders with old fashioned fiberglass mat and resin.
    Mark Edmondson
    Dallas, Texas
    Texas Chapter
    • Paul Y.
      • September 30, 1982
      • 570
      That is what I use also.
      It's a good life!
      • Domenic T.
        • January 29, 2010
        • 2452
        On small holes I use JB weld. I put tape on both sides to keep it from running.
        Dom
          • 6950
          I have used JB Weld also for small holes and cracks, Put a piece of masking tape on one side and fill on the other side. much quicker and lasts forever. I also used a razor blade as a spreader.
          • Richard R.
            • January 5, 2010
            • 270
            Whether JB Weld or glass and resin, it has to be better than the bathroom caulk I just removed from 4 more holes I found.
            Thanks Guys,
            Rich
