C2 Posi traction question - NCRS Discussion Boards
  • Chester C.
    • May 29, 2013
    • 154
    With one rear wheel on the ground, should I be able to rotate the opposite wheel that is off the ground if I have a posi traction rearend.
  • Patrick B.
    • August 31, 1985
    • 2017
    Re: C2 Posi traction question
    Definitely not without a whole lot of effort, and the trans should be in neutral too.
    • Gary R.
      • April 1, 1989
      • 1808
      Unless it is a tuned posi, which I doubt you have.
      • Chester C.
        • May 29, 2013
        • 154
        Just wanted to make sure I'm headed in the right direction, thanks chet
