Speedometer cable installation - NCRS Discussion Boards
  • Walter R.
    • January 6, 2009
    • 271
    I am installing speedometer cable after refurbishing instrument panel. AIM shows cable going streight through firewall where I have an access cut in the firwall insulation and a plastic plug on engine side firewall. Wanted to make sure all engine sizes go through this access and do not exit where Tach and Oil pressure line exit.
    Re: Speedometer cable installation
    Walter -
    The speedo cable routing shown in UPC 12 is for a 3-speed manual, which had the speedo drive on the driver's side of the transmission (every part shown in UPC 0 through UPC 14 is for a "base car" with ZERO options; all option parts are shown in the RPO Section of the A.I.M.). Cable routing for a 4-speed is shown in the Option section, M20, and it's different than the 3-speed, as the speedo drive on a 4-speed is on the passenger side of the transmission.
    • Walter R.
      • January 6, 2009
      • 271
      Thank You for information
