I have a Power Steering problem with my 1968, 427 L-36.  When the unit is cold, I have power steering but as the unit warms up the power steering assist goes away.  As long as the car is moving, I do not notice the problem but turning the wheel getting the car back into the garage, there is no power assist.  The system use to make a slight noise when I turned the wheel going back into the garage after it was warmed up, but now that does not happen. Of the  3 major components of the system, the pump, power control valve and steering cylinder, what do you think is the problem or should I replace all 3 components? The entire system, except for the hoses, is at least 15 years old and could even be original. Thank you for your help.
