I have a 1969 conv. tripower with factory air. I top Flighted this car in '07 at the Texas Regional. I want to do it again. Chuck Anderson from that area assisted me in getting the car ready to judge and always does a fantastic job. I live in Shawnee Okla. and I would like to find someone closer here in Okla. to help resolve my wiper door bumping up slightly and right back down on start up. Also wiper washer issue, And fine tuning the newly restored tripower carbs. I want a corvette guy, not just you run of the mill mechanic. Can anyone make a recommendation. Thankyou. Gary H
I've got those vacuum door blues !
Re: I've got those vacuum door blues !
Gary, I had a similar issue with my 72 , there is a plastic vacuum switch that mounts under the pass side wiper that was my fix.New England chapter member, 63 Convert. 327/340- Chapter/Regional/national Top Flight, 72 coupe- chapter and regional Top Flight.- Top
Ok Ed, I'll check that out.I've pulled a 10" vacuum on the complete system and it holds for about 15 minutes.I'm still going to be searching for a good corvette mechanic here in Okla. that i can go to on occasion when needed. Thankyou for your time- Top
