Help Needed Identifying Radiator Caps - NCRS Discussion Boards
  • Michael B.
    • January 20, 2014
    • 187
    I recently acquired some old radiator caps and I'd appreciate some help in identifying their proper application.
    The cap in photo one has a flat rivet and I believe it is correct for either my 72 base engine/automatic, or my 72 LT-1.
    The cap in photo two has a concave rivet and I'm not sure what years are correct for that cap.
    I have no idea what the caps in photos three and four are for.
    Thanks.
    Mike
  • Jimmy P.
    • June 24, 2014
    • 1695
    Re: Help Needed Identifying Radiator Caps
    Michael,
    I'm by no means an expert on caps but I've done some research while getting the correct cap for my 73. The cap ( flat unplated brass rivet) in photo number one looks correct for 70-72 vettes with copper radiators & brass expansion tanks as you stated. The cap (depressed unplated brass rivet) in photo #2 looks correct for 68-69 vettes with copper radiator & brass expansion tanks. The other two I'm not sure of either but I would guess they are for earlier applications before 68. I know they are not correct for 1973 and up. Hope this helps
    Jimmy
    1973 Convertible
    L48,M20,N40
    Mille Miglia Red/Oxblood
    • Russ S.
      • April 30, 1982
      • 2162
      Jimmy, What cap did you conclude was correct for your 73 and what is the build date of your car?
      Originally posted by Jimmy Patitucci (60161)
      Michael,
      • Harmon C.
        • August 31, 1994
        • 3228
        Photo #3 is stainless and is a service replacement.
        Lyle
        • Peter L.
          • May 31, 1983
          • 1930
          Photo #4 is the 15# RC-15 radiator pressure cap configuration stamping used on GM cars with C60 air conditioning from the early 1960s (maybe even earlier) up thru 1965 production. As far as I know, the 15# RC-15 radiator pressure cap with that specific cap stamping configuration was not OE on Corvettes. With 1966 production the cap configuration stamping changed to the configuration like the #2 cap. Pete
          • Jimmy P.
            • June 24, 2014
            • 1695
            Russ,
            none of the ones pictured above are correct for my car. I have the correct one for my car. April 30th build date.
            Jimmy
            1973 Convertible
            L48,M20,N40
            • Michael B.
              • January 20, 2014
              • 187
              Thanks to everybody for their responses.
              Thank you Pete for your help with the cap in photo 4.
              I'll look for you in Denver in a couple weeks.
              Mike
              • Harmon C.
                • August 31, 1994
                • 3228
                The RC-33 in the center is a one year cap and hard to find.
                Lyle
                • David L.
                  • July 31, 1980
                  • 3310
                  I believe that the cap shown below is correct for 1970 models and probably other years as well.
                  Dave
                  • Russ S.
                    • April 30, 1982
                    • 2162
                    Don't forget the RC29 that came on at least some of the early 73s up thru at least vin number 8154.
