Voltage regulator conversion to solid state - NCRS Discussion Boards
  • Michael G.
    • January 1, 1997
    • 1251
    Thought I saw someone advertising in the Driveline converting voltage regulators to solid state electronics.....however after going through 4 copies did not locate anything. Anyone know anything? Thanks.
  • David S.
    • December 1, 1982
    • 310
    Re: Voltage regulator conversion to solid state
    Mike try the May-June Issue page 110 top
    Dave
    • Michael G.
      • January 1, 1997
      • 1251
      Sorry to report Dave nothing there regarding regulator conversion on pg 110 May-June. Who or what are you seeing?
      • Leif A.
        • August 31, 1997
        • 3653
        Michael,
        Is this conversion for one of your midyears? If so, you can simply buy a Wells VR-715 solid state from any FLAPS (about $20). Remove the plastic cover (glued on) and install the Delco cover from your original voltage regulator with the two screws from the Delco. About a 5 minute job.
        Leif
        • Frank D.
          • December 27, 2007
          • 2703
          Absolutely -- did it on my '63.
          If its on a C1 you are slam out of luck ... the only person in the world that made solid-state V/Rs for generator driven Corvettes died a couple of years ago in his mid-90s. I was lucky to snag two of the conversions before the gent passed away...one has been in my '61 for 5 years now.
          • Michael G.
            • January 1, 1997
            • 1251
            Originally posted by Leif Anderson (29632)
            Michael,
            Thanks Leif but that isn't the case. Just needing the name and contact info for the company or person.
            • David S.
              • December 1, 1982
              • 310
              Mike Driveline May-June 2015
              Page 110 Services & Miscellaneous
              Top Ad
              New Voltage Regulator, restoration/up-
              Contact Bill Caldwell
              203-925-0940
              NCRS # 15218
              • Michael G.
                • January 1, 1997
                • 1251
                Duh, completely missed it. Thanks guys.
                Nope, it's not for a C-1.
                  • 6956
                  Mike, Bill Caldwell did my 63 regulator assy and converted it to solid state and does all the re-plating and painting of cover, super nice job and it looks as the original when looked at from the outside.
                  • George R.
                    • February 1, 2001
                    • 19
                    A lot of local guys swear by Bill Caldwell. The VR comes back looking and functioning perfectly, but with the modern electronic conversion. Quick turn around too. Besides that, he's a good guy.
                    • Mark H.
                      • November 1, 1976
                      • 121
                      Had Bill Caldwell restore the VR on ours a few months ago. Works perfectly and looks like new. Highly recommended.
                      • Mike K.
                        • February 25, 2010
                        • 68
                        Would highly recommend you contact Bill Caldwell to restore yours. He does excellent work and
                        is very quick about it.
