need carb date help please - NCRS Discussion Boards
+ More Options
Posts
  • Paul L.
    • July 7, 2015
    • 38
    Anyone close to vin 194677S109108(Jan. 27, 1967 birthday) could you please tell me your carb date.
  • Ara G.
    • January 31, 2008
    • 1108
    Re: need carb date help please
    Paul, you may want to tell us what exact motor you have in your car. A 390 smog car having a 3815 carb will be a rare carb that's not pulled off the rack with regularity, whereas a 3810 that's applicable on all 300 and 350hp non smog cars were much more used. The 6 month window for judging is one thing, but actuality/reality is another. Let us know what you got and maybe we can assist. By the way, welcome aboard!!!!!!!!! ARA
    • Joe R.
      • May 31, 2006
      • 1822
      Paul,
      Which engine do you have? I can't speak to 67's specifically, but in general the small block dates are closer together. I have a 66 L72 (427 / 425), the carb is dated pretty close (maybe two weeks prior) to the engine assy date (which is probably more important than the car assy date in this case).
      Joe
      • Paul L.
        • July 7, 2015
        • 38
        Thanks for reply, this car has a 390 hp, is not a smog car, believe it was originally sold in Columbus, Ohio.
        • Paul L.
          • July 7, 2015
          • 38
          427, 390. Thanks for reply. Not a smog car.
          • Paul L.
            • July 7, 2015
            • 38
            Also, production date is 1-27-1967, so I know carb date must be sometime before that.
            • Michael W.
              • April 1, 1997
              • 4290
              Originally posted by Joe Raine (45823)
              Paul,
              Joe
              The carb date has no relevance to the engine assembly date since it was installed at the car assembly plant and not the engine assembly plant.
              • Mike E.
                • June 24, 2012
                • 920
                I think I've read somewhere that Holley carbs were produced in large batches so the dates are kind of all over the place.
                Is there any real data out that supports that?
                To my knowledge anything between 6 months prior and a few days before the build date would be acceptable.
                Mike
                • Joe R.
                  • May 31, 2006
                  • 1822
                  Right you are! My bad!!!
                  • Larry M.
                    • January 1, 1992
                    • 2700
                    Get a carb 2-6 weeks prior to the CAR build date and you will be fine. Most/many carbs fall into this range for non-special/regular motors, although NCRS allows 6 months.
                    Larry
                    • Paul L.
                      • July 7, 2015
                      • 38
                      thanks very much
