66 radiator support - NCRS Discussion Boards
66 radiator support
  • Jim D.
    • August 31, 1997
    • 58
    66 radiator support
    Are there differences between the big and small block radiator supports for the 66 model year?
    • 43271
    Re: 66 radiator support
    Jim------
    Yes, there definitely are differences. The basic frame of the support is the same but brackets and side plates are different.
    • Jim D.
      • August 31, 1997
      • 58
      Is there some place I can go to see these differences?
      • Wayne W.
        • April 30, 1982
        • 3605
        The basic difference is the radiator mounting and opening. The BB has saddles for mounting. Both will fit the body.
          Jim -
          See photos below - the small-block aluminum radiator has two pins at the bottom that mate with donut-shaped rubber isolators in two welded brackets at the bottom of the support, and the big-block brass radiator mounts in a pair of welded saddles at the bottom and another pair that's bolted at the top; the radiator opening is also different between the two supports.
