1965s with factory installed M22 - NCRS Discussion Boards
  • Gene M.
    • April 1, 1985
    • 4233
    #31
    Re: 1965s with factory installed M22
    Originally posted by Larry Evoskis (16324)
    Gene: Right now Chevy is winning about 55-60% of the races. NASCAR does not want that to increase and does not want to start making "individual engine rules". With a "all out LS Developed Nascar engine" and same rules for all manufacturers the winning % would increase by
    a ton. Ford may have a lot going with the current Mustangs but have absolutely nothing going with "push rod" engine technology which has to
    run in NASCAR. Totally agree with your last comment on the Third Manufacturer! Larry
    Too bad Dodge is out of racing. They were strong with Penske. Good point about Ford, NASCAR would demand push rod only engines.
    • Tom D.
      • September 30, 1981
      • 2145
      #32
      I have now learned from owner number 4 that the original engine was rebuilt, and once rented to Rinzler Racing for the (C3) Holiday Inn Corvette to use at Lime Rock. The engine was supposed to be returned to owner number 3 after that race. Still need to determine if that actually did happen...
      This relates to my mention of the engine in 1965 racer number 116538 - See above for the prior post. THANKS!
      Last edited by Tom D.; August 12, 2015, 11:21 PM. Reason: To add information to my prior post.
      https://MichiganNCRS.org
      Michigan Chapter
      Tom Dingman
      • Bill W.
        • March 1, 1980
        • 2000
        #33
        Tom .Did they "rent" the transmission at the same time ???
        • Gene M.
          • April 1, 1985
          • 4233
          #34
          Originally posted by Bill Williamson (3245)
          Gene . Thats what I thought , It had to be for the brake line or to hold the e brake cable from hanging .??? But why is there not more people who have actually seen this . I now know of three cars all 396s a 16000, a 17000 and now a 23000 .
          Bill, still thinking along this same path, picture a substitute GM worker doing this brake line job for a short time (couple days, or so) and having his preferred method of holding the brake line with tape and didn't remove it when done on all chassis......... I could see it just staying there because it didn't bother anything further on down the line.
          • Bill W.
            • March 1, 1980
            • 2000
            #35
            Gene , I agree with you , It looks like it would be to hold the brake line or the E brake cable and its the same black paper tape that is used on the inside of the doors . BUT why is there only three cars so far that have it and all three are 396s and all three were race cars ?? I dont know . I am going to put new tape on my frame and maybe someday it will come out . PS it was not the same tape as used on the body mounts .Bill
            • Tom D.
              • 2145
              #36
              I am putting the tape back on also.
              Tom D.
              Michigan Chapter
              Tom Dingman
