1970 Corvette Alarm Key? - NCRS Discussion Boards
  • William H.
    • January 1, 2006
    • 209
    I have a 1970 Corvette that came in boxes and I'm trying to figure out my key situation. J is for the ignition and the K is for the locks/alarm? Or, was the B for the alarm? My VIN is 6507 (early March car). They all look original with plenty of use but not sure if somebody added a key? Thanks for the expert's opinion.
    Bill
    Bill Hyndman
    The 'Sound of Freedom' if not a UH-60 Blackhawk, then it must be a Corvette!
    1962 Big Brake Fuelie
    1965 Fuelie Convertible
    1968 L89 Convertible
  • Michael G.
    • March 2, 2008
    • 485
    Re: 1970 Corvette Alarm Key?
    Most likely your alarm cylinder had been replaced with a '71 (B) cylinder. These electric switch cylinders were prone to corrosion and often needed to be replaced. You are correct, the alarm should be the (K) key operation along with the other locks.
    • Kenneth B.
      • August 31, 1984
      • 2087
      I see that 2 of the keys have the letter stamped side ways to the key & the alarm is stamped up & down. I thought all 70 keys were stamped up & down.
      • Peter L.
        • May 31, 1983
        • 1930
        Ken - Based on my experience, the keyway code letters, "J" & "K" stamped on the key shafts on examples of "original" 1970 Corvette keys stamped w/1970 GM KEY NUMBERs on the KNOCK OUTs in place &/or w/stamped KOs separate have had the keyway code letters stamped as on the "K" code key in Bill's photo. The 1970-1972 NCRS JUDGING MANUAL, 3rd Ed., p. 37 shows examples of original 1970 "J" & "K" keys with the keyway code letters oriented as on Bill's "K" key. There is also a discussion on the orientation of the code letters on p. 36 that indicates that the orientation of the code letter stamping on "originals may also have the letter oriented at a 45 degree angle" & that the orientation of the letter "simply indicates that the key was manufactured for Briggs & Stratton by a contractor." Who says that working on old cars isn't INTERESTING. Pete
        • William H.
          • January 1, 2006
          • 209
          Thanks for everyone's help in solving my mystery. I'm concluding that the original Briggs and Stratton lock cylinder was replaced with a B code key and cylinder. Much appreciated.
          Bill Hyndman
          • Kenneth B.
            • August 31, 1984
            • 2087
            I am in the same boat as you are. My 70 454 VIN 7601 has the later cylinder also& my extra set of keys are stamped like yours. & must have been replaced. It mist have been replaced for not working as the car had original paint & was not hit in the ass. My February built 70 LT-1 has the BS lock & key.
