1984 EGR Valve Question - NCRS Discussion Boards
  • Thomas F.
    • November 11, 2008
    • 204
    I need a little help with a technical question concerning my 1984 Corvette. It is my understanding (correct me if I am wrong) that for this valve to function as GM intended, it requires a certain amount of exhaust back pressure. Assuming this is true did I make a mistake when I replaced my cat. and mufflers with more free flowing designs?
    • 43263
    Re: 1984 EGR Valve Question
    Thomas------
    I'm quite confident that a change in the exhaust won't affect EGR system operation.
    However, a change in the exhaust configuration, especially if the catalytic converter was eliminated, will definitely cause other engine problems.
      • 6954
      Tom, Some EGR valves do work with some back pressure along with vacuum, I would think the GM service manual should help spell it out. I cannot recall if 84 did. I would not think a free flowing cat. would have any effect though.GM went through a lot of driveability issues with those dam valves so it helped some cars and not others with back pressure.
      • Page C.
        • February 1, 1979
        • 802
        Not sure about 1984's but as you move into the later 1980's early 1990's the EGR valves have a "N" (negative pressure) or a "P" (positive pressure) stamped in the the EGR valve cover after the part number. Like Ed said they can be a nightmare.
