Exhaust popping fix explained - NCRS Discussion Boards
  • Gary S.
    • July 31, 1992
    • 1633
    First of all, thank you all who posted. My moderate+ exhaust popping during deceleration, going downhill, and shifting was indeed the AIR diverter valve failure. I talked with Bill Hodel and the fix is:
    1. replace at $500 (not in the cards right now)
    2. replace with similar or look alike at $300
    3. Neuter the air pump $100. This is John Hinckley's solution and is fully reversible. Remove the vanes of the air pump, block the signal hose to the pump and block the exhaust gases at the AIR manifold tree.
    I chose door #3 and, although not as easy as welding the tube closed at the exhaust manifold as was suggested in my first post. In addition, I checked my carb and it was properly adjusted. The car runs amazingly well. At cruise, the car never ran poorly but at partial throttle and low speed acceleration it wasn't a pretty ride. Now it is just as one would expect with a beautiful sound, peppy acceleration and great low speed, partial throttle acceleration.
    Thank you all.
    Gary
  • Mark E.
    • April 1, 1993
    • 4607
    Re: Exhaust popping fix explained
    I like your route of "neutering" the pump rather than closing the tubes in the manifold. Doesn't neutering eliminate most of the parasitic power loss, while closing the tubes might actually increase pump pressure, and hence, power loss?
    Your results explain why so many of these systems were simply removed back in the day. Not to mention a cleaner looking engine bay...
    Does a diverter valve really cost $300 - 500?
    Mark Edmondson
    Dallas, Texas
    Texas Chapter
    • Gary S.
      • July 31, 1992
      • 1633
      Actually, I got the term and the idea from John Hinckley and I recall that he said that there is no longer anything in the pump to create drag and it is essentially a pulley. I will be sending my pump out in a week or two.
      Diverter valve at $500? Yes, for a correct part. I was quoted that for an exchange or a rebuild of mine. For a couple of hours of work both from the top of the engine bay and underneath it, I think this was the way to go, imo. Of course, as I get older my aches and pains become major after this kind of work. In the end, it was worth it because the car runs so much better.
      Gary
      • Edward B.
        • March 29, 2013
        • 691
        Gary, you can do the job yourself. It's dirt simple. All you need are some standard tools. I did this on my L36 a year or so ago.
        Here are a few sites that show you how:
        Ed
        • Gary S.
          • July 31, 1992
          • 1633
          Interesting Ed. But a hammer and chisel to break the vanes apart? Did you really do that or did you try and remove them intact? It looks easy except for the hammer/chisel part.
          • Edward B.
            • March 29, 2013
            • 691
            Nope. just chisel them out. It was very easy and here's the result.
            (NOTE: The picture attached is NOT my original 1969 L36 AIR pump, but one I happened to have laying around in my garage.)
            However, if you have a rare pump, or numbers matching and don't feel comfortable doing this yourself, by all means send it out. Or, get a cheap one on ebay to practice with!
            Ed
            • Mark E.
              • April 1, 1993
              • 4607
              If neutering involves a hammer and chisel, is it really "fully reversible"? (For some reason, I winced while typing that.)
              If not, maybe save your original AIR pump for shows and neuter another for the street.
              Mark Edmondson
              Dallas, Texas
              Texas Chapter
              • Gary S.
                • July 31, 1992
                • 1633
                "Fully reversible" is Bill Hodels description. Hammer and chisel seems most definitely non-reversible unless there is a rebuild in store.
                • Edward B.
                  • March 29, 2013
                  • 691
                  I have no idea what Bill's procedure is, but my way is definitely NOT reversible!
                  (Unless I can get my wayback machine working)
                  Ed
                  • Gary S.
                    • July 31, 1992
                    • 1633
                    Pretty soon those of us who know about the "way back machine" will have to start splainin to the others
                    • Edward B.
                      • March 29, 2013
                      • 691
                      I guess it's actually WABAC MACHINE!
                      Ed
                      • Gary S.
                        • July 31, 1992
                        • 1633
                        Exactly. Now I don't know your age but I watched this. Can I use it to back to 1963 and order up a Corvette?
                        I am a stickler for searching on the various websites (and I DID search and read here) I visit before I pose a question. The thing I learned here was that there are very few surprises and even fewer new malfunctions on these old cars. I posed my original question with the clear understanding that this was carb or ignition related, not emissions. Of course, I was wrong. I had read numerous exhaust popping questions and many of you suggested the diverter valve to the poster, a few suggested timing, valves, rich/lean carb settings, etc. Because of the strong fuel smell when parked in the garage, I felt certain it wasn't the diverter valve. After fixing my problem, I went back and re-read the searches I had done and the solution was as plain as day.
                        Thanks to all and now all I have to do is go back under the car and install some ignition shielding and the drive this car.
