Upper radiator hose - NCRS Discussion Boards
Upper radiator hose
  • Gary V.
    • April 15, 2012
    • 76
    Upper radiator hose
    What would cause the upper radiator hose on a 79' small block 350 to look like all the air was sucked out of it from the inside? I found it that way a week after driving the car. I loosened the clamp on the thermostat housing and it came back into it's round shape again. I drove the car and everything seems fine. The thermostat opens and temperature is in spec. Water pump is good and no leaks. I had heard that the lower hose has the spring in it to prevent it from collapsing like this upper hose did. any thoughts?
    Gary
    • 15706
    Re: Upper radiator hose
    The cap has both pressure and vacuum relief valves, and the vacuum side may be malfunctiong. Most auto parts store have radiator cap pressure testers, and they might also be able to test the vacuum relief function.
    If it happens again, slowly open the cap and listen for the sound of air rushing in.
    • Gary V.
      • April 15, 2012
      • 76
      Thanks Duke,
      It happened again and I did hear the air going in and the upper hose went back to normal diameter. I replaced the cap with an NOS OEM AC Delco replacement one instead of a re-pop that was on there. I will let you know the outcome.
      Gary
      • Gary V.
        • April 15, 2012
        • 76
        The new OEM cap fixed the problem the system is working like it should drawing from the coolant recovery bottle, not collapsing the upper radiator hose. Thank you for the help.
        Gary
          • 43277
          Gary
          Gary-------
          ....just another example of functionality problems created by reproduction parts. In this case, the vacuum relief function of the reproduction cap must be non-functional. Maybe they didn't even include such a function in the design.
          • Gary V.
            • April 15, 2012
            • 76
            Hi Joe,
            I couldn't agree more! The biggest problem restoring this car has been reproduction parts and fasteners. Many were poor quality and had to be replaced more than once. Others like this cap created problems. It's a shame because I don't even drive the car that much for things not to work right or fall apart or leak.
            Gary
