Need paint code for '66 interior trim code 414 - NCRS Discussion Boards
  • Hans R.
    • March 1, 1976
    • 91
    I have the booklet with the color chips that states paint codes for the exterior paint. But I do not know where to find the paint code
    for the interior paint for the parts that should be painted blue. The car is a 1966 coupe with white 972 exterior and blue 414 interior.
    What is the interior paint code? Is it the same as the exterior 976 Nassau Blue?
    I assume all the blue parts that should be painted, use he same paint, or? I need to ask because at present the parts vary very much in appearance. But I guess they might have been repainted or the 49 years on the road has taken it's toll.
    Thanks for any help on this
    Hans Ryden #868
    Stockholm Sweden
    Hans Ryden #868
  • Gene M.
    • April 1, 1985
    • 4232
    Re: Need paint code for '66 interior trim code 414
    Hans,
    If you are spraying lacquer the nassau blue inside is same as body either sprayed sorta dry or add flattening agent. R&M lacquer nassau blue is 61747. This number is 30 years old.
    All I would suggest is try to find a single stage urethane if that is your paint choice.
    Google has most paint suppliers mix codes if you have the GM code. There has been discussion on this site on codes in the past. Try a search, as nassau blue is a very popular color.
    • Wayne M.
      • March 1, 1980
      • 6414
      Here are the interior codes for 1966. There were several glosses an codes for '66 interiors (same case for saddle tan and blue in both 1965 and 1966). Depends on what the part is. There's been discussion of this before.
      This was published in Chevrolet Service News.
      • Hans R.
        • March 1, 1976
        • 91
        Tanks Gene and Wayne for you help.
        HR
        Hans Ryden #868
