Just tidying up the last few things before I do the initial fire up on my L71. Installed the alternator yesterday, and I am sure it has the correct deep grove pulley, and I ordered all both mounting brackets, brand new for this application, but it seems like the pulley is too far forward. Any suggestions?
1967 alternator pulley
Re: 1967 alternator pulley
Dave,
I don't know what, if any, affect this will have but I believe the top bracket on your alternator is on the incorrect side of the boss. If I remember correctly, the bracket is on the backside (firewall side) of the alternator boss with the bolt and washer inserted from the back side.Leif
Top Flight 2017 Lone Star Regional- Top
Dave, I believe you have the incorrect pulley. Appears to be too thick, which would move the belt forward and misalign with the water pump pulley. Attached are photos of my 67 BB. Note upper bracket position on the alternator.......Attached Files- Top
Thanks guys, I had the top bracket, bolted to the block instead of the tab on the intake, but the pulley is still off, I think I need the one you have Stephen, strange though, I see this pulley in pictures of other L71 cars.- Top
Dave, look at AIM UPC N40 A7 and you'll see the belt assembly "order" where a PS car drives the alternator, thus a "thick" pulley, as the alternator belt is forward of the PS belt.- Top
Pulley.jpgMounting.jpgDon Anderson- Top
