'65 Brake Pedal - NCRS Discussion Boards
'65 Brake Pedal
  • Don H.
    • December 1, 1981
    • 1496
    '65 Brake Pedal
    I think my '65 with power brakes should have the linkage in the upper hole (see photo with arrow). Am I correct? Thanks, Don H.
  • Russ S.
    • April 30, 1982
    • 2163
    Re: '65 Brake Pedal
    No Don. It should be where it is. The upper hole at least in 66 has a small bracket bolted there that contacts the brake switch.
    • Donald A.
      • March 1, 1987
      • 243
      Re: '65 Brake Pedal
      Hi Don, I agree with Russ, the linkage for PB in '66 attaches to the bottom hole, the upper hole is where the switch plate is bolted as seen in my photo below -Don
      Don Anderson
      • Timothy B.
        • April 30, 1983
        • 5202
        Re: '65 Brake Pedal
        [ATTACH=CONFIG]61609[/ATTACH]
        Please get the correct clip that holds the pin in the clevis, that is a important safety item. The correct clip is shown in post #3.
        • Leif A.
          • August 31, 1997
          • 3653
          Re: '65 Brake Pedal
          http://www.parts123.com/parts123/yb.dll?parta~partsort Part #47-19B
          Leif
          • Don H.
            • December 1, 1981
            • 1496
            Re: '65 Brake Pedal
            Thanks everybody. Don H.
