Lifting Eye Color for Automatic - NCRS Discussion Boards
  • Mike K.
    • February 25, 2010
    • 68
    In reading the judging manual for 68 - 69, the lifting eyes were attached to the engine and bell housing and
    then sprayed engine orange at the engine plant. While this is understandable for stick shift cars, automatic
    transmissions were not sprayed and should show no overspray - leaving them natural.
    My question would be what color should the back lifting eye be since an automatic transmission was not painted
    and was attached in natural finish at St Louis plant.
    Thanks in advance,
    Mike
  • Russ S.
    • April 30, 1982
    • 2163
    Re: Lifting Eye Color for Automatic
    Mike, There should not be a rear lifting eye on a 73 automatic. I know the judging Guide says it is there however that is incorrect.
    • Mike K.
      • February 25, 2010
      • 68
      Russ, Thanks for the reply, but I have an early '68. Hoping that the Guide is wrong for this one as well.
      • Russ S.
        • April 30, 1982
        • 2163
        Sorry Mike. I had just been reading and dealing with a 73 issue and had 73s in my head.
          • 15632
          Thanks in advance,
          Mike
          Mike -- you don't tell us if you have a Small Block or Big Block. Aluminum heads make a difference as well.
          This will work for 1968 to 1972:
          Small Block/M40 = No rear lifting eye
          SB/manual trans = may be some orange overspray on rear lifting eye, then again maybe not
          BB/iron heads/all transmissions = orange rear lifting eye
          BB/Al heads/all transmissions = unpainted rear lifting eye.
          • Mike K.
            • February 25, 2010
            • 68
            Terry,
            Thank you for responding to my thread. I have a SB with M40 Trans.
            Based on your replay, I would not have a rear lifting eye. Would that also
            be the same for the front? Judging manual is very unclear in this regard.
            Any help is greatly appreciated.
            Mike
              • 15632
              Terry,
              Mike
              You still need to have a front lifting eye.
              • Mike K.
                • February 25, 2010
                • 68
                Terry,
                Again THANK YOU for the direction here, I really appreciate it.
                Mike
