Jolt, when shifting from Park to Reverse (TH 400) - NCRS Discussion Boards
  • Ruedi K.
    • December 12, 2011
    • 242
    Hello together,
    I am experiencing a problem with the turbo hydramatic 400 automatic transmission in my car. (1970 LS5 Corvette).
    Whenever I shift from P to reverse or from reverse to 3 I notice a jolt. It's like a punch and you can really feel it.
    Could this be the modulator of the transmission? However, the car shifts nicely when I drive it. This is only when I do not move and put the tranny in reverse. Idle speed is at 550 RPM.
    Before I order any parts I would like to ask you for advice, what could cause this problem? Transmission had been rebuilt some years ago. Maybe somebody has had the same issue?
    Any help is really appreciated.
    Thank you
    Best regards from Switzerland
    Ruedi
  • Mark E.
    • April 1, 1993
    • 4536
    Re: Jolt, when shifting from Park to Reverse (TH 400)
    I'm not an automatic tranny expert, but a "jolt" when shifting into reverse or drive might also be caused by too much drive train lash. So check for worn u-joints, differential, yoke during your trouble shooting.
    Regarding the tranny, a good service manual should have a symptom/trouble shooting guide that might provide insight.
    Are there many TH400 shops in Switzerland?
    Mark Edmondson
    Dallas, Texas
    Texas Chapter
    • Mark E.
      • April 1, 1993
      • 4536
      You might check the motor mounts also.
      Mark Edmondson
      Dallas, Texas
      Texas Chapter
      • Paul D.
        • September 30, 1996
        • 491
        Most likely source of this type complaint is the pinion mount cushions. Check them for looseness or deterioration. Chip.
        • Mark E.
          • April 1, 1993
          • 4536
          Good catch. Yes, check the front differential mount also. This and other drive train lash possibilities mentioned can cause a clunking.
          But from your description I'm not sure if you're hearing the drive train clunking or if the transmission is just shifting into gear too harshly. Knowing the difference will help you trouble shoot this.
          Mark Edmondson
          Dallas, Texas
          Texas Chapter
          • Ray G.
            • May 31, 1986
            • 1189
            Hello;
            Idle speed correct ?
            Ray
            I hope you dance
              • 11643
              I assume you've check the fluid level as well? I've seen this with low fluid.
              Just a thought in addition to what has already been said.
              • Steven B.
                • April 11, 2012
                • 233
                How does the shift into reverse or drive compare to the 1-2 and 2-3 up-shifts? A shift kit can make some of these shifts seem harsh along with a torque converter that has a low rpm stall speed. In actuality, a firm shift is more desirable than a soft shift. Soft shifts are OK for the family car where you don't want to give everyone whiplash on an up-shift, but for a performance car, a firm shift is more desirable. Smooth shifting is generally accomplished by easing clutch engagement, accomplished by allowing some initial clutch slippage when the pistons apply. The compromise is that frictional heat is generated that ultimately breaks down internal components sooner. If your "jolt" includes the car wanting to move while the brake is applied, it sounds like firm engagement, and if you are experiencing something else (especially if your up-shifts are not firm), the problem very well could be some of the components mentioned earlier such as the mounts or some slop in the drive train. Others may have additional thoughts.
                Steve
                • Russ S.
                  • April 30, 1982
                  • 2162
                  When I purchased my 73 new with a turbo 400 it shifted from park to reverse or from neutral to drive with a jolt and still does. Unless your talking about a severe jolt I would say it is probably normal.
                  • Ruedi K.
                    • December 12, 2011
                    • 242
                    Hello together,
                    Thanks for all the replies. There are no shops specifically for the TH 400 transmission here in Switzerland. I will tackle this next winter and will check the points you mentioned. It drives well, the jolt is not that hard. Checked fluid level and was as it should be. Motor mounts are new. Shifts quite softely when driving.
                    Now looking forward to the next meet. Had enough rain so far, here in Switzerland
                    Thank you
                    Have a good week
                    Rudy
