67 4 speed shift pattern plate - NCRS Discussion Boards
  • Ralph P.
    • February 1, 1990
    • 253
    I need a correct ( or NOS) shifter plate . Any info on who makes the most correct part for a 67 ?
    Thanks !
  • Philip C.
    • December 1, 1984
    • 1117
    Re: 67 4 speed shifter plate
    Long Island Corvette Supply #800-466-6367 or www.licorvette.com part #32-15B $25.00 32-16B for the bracket bolt set 32-17B for shifter mounting bolts set. Go to the online catalog Phil 8063
    • Ralph P.
      • February 1, 1990
      • 253
      Thanks, Philip.... But, the part I'm questioning I guess should be called the "shift pattern plate" . I do see an old thread ( 2013) on the subject indicating that the repros are all different from originals. I wonder if there's been any improvements since then?
      • Jim S.
        • March 1, 1986
        • 1408
        Ralph,
        I was going to reply by saying no to the improvement question . I ordered several and remembered them all being nowhere close . I thought I was going to tell you that I redid my original . I was wrong .
        I went to get some pics of the reproduction ones , and found my original along with them . Then looked at my console and noticed that I had in fact replaced it with a new one . It is not perfect , but it is close .
        See all the pictures attached. The one in the center is the one I chose, the two on either side are the first two repros I got , or at least the last two , I am sure I have a few more lying around somewhere . The bottom is my original , and you can see why I needed a new one !. (it wasn't as bad as it looks now , that was after me trying to sand out all the scratches , then giving up )
        Now that means that someone got close. The bad news is I don't remember who . But a least there is hope .
        Jim
        Ps. You are welcome to either or both of the two new ones.
        • Ralph P.
          • February 1, 1990
          • 253
          Have to laugh,as I would also never remember from what vendor I got lot's of stuff..... Anyway, your's looks very close & I would like to know if you run across the source!
          THANKS
          • Jim S.
            • March 1, 1986
            • 1408
            Will do. However time is not our friend on this one !
            Jim
