54/58 Gas Gauges - NCRS Discussion Boards
54/58 Gas Gauges
  • Brad H.
    • August 12, 2007
    • 724
    54/58 Gas Gauges
    Hi... As of recently both my gas gauges with full tank read only 1/2. As tank empties gauges will drop normally. Is it easiest to check gauges first? (what is exact procedure) or mess with the sending unit(procedure again) have checked all grounds and they are clean and tight. Did I miss anything? Thank's guy's. Brad.
  • Richard M.
    Super Moderator
    • August 31, 1988
    • 11366
    Re: 54/58 Gas Gauges
    Brad,
    To test the gauge in the cluster, you need a variable resistor, 0 to 30 ohms. Disconnect the sender wire and connect your resistor between the sender terminal on the gauge and ground. Vary the resistor and watch the gauge.
    To test the sender, you'll need a ohm meter to read all positions, but you'll need to remove the sender to test it by moving the float. But in your case if the tank is full, you could remove the sender wire and connect your meter between the sender terminal and ground to test for "full"(~30 ohms).
    Full= ~30 ohms
    Empty = ~0 ohms
    • Brad H.
      • August 12, 2007
      • 724
      Thank you Richard. Brad.
        Brad -
        Try the article below to diagnose the C1 fuel gauges.
        C1FuelGaugeTech.pdf
        • Brad H.
          • August 12, 2007
          • 724
          Hi guy's... gauge's seem to check out fine. I took the sender out and noticed right off that the float at the same line where it snaps into bar has a 1/2 crack in it and it had a lot of gas in it. Have not checked anything else out yet. Could this be the problem and should I check the unit out? Thank's, Brad.
          • Richard M.
            Super Moderator
            • August 31, 1988
            • 11366
            Brad, I'd do the electrical test of the unit and if it's good you can replace just the float.
            The page you were looking for was not found or has been deleted. Search Corvette Parts by year or category instead.
            • Brad H.
              • August 12, 2007
              • 724
              Hi guy's... sender checked out fine...soldered crack on float, checked and now is fine. Thank's again. Brad.
