Modern Radio for C2 Cars - NCRS Discussion Boards
  • Bill L.
    • April 1, 1985
    • 349
    Does anyone have experience with Mike Hagan Antique Auto Radios ---- specifically c2 cars (67) -----
    I know he offers an upgraded radio with newer internals and a restoration service --
    The upgraded radios look really nice but the question is do they judge out correctly? Both looks and operation?
    Bill
  • Russ S.
    • April 30, 1982
    • 2162
    Re: Modern Radio for C2 Cars
    They fail PV as the indicator won't move with the push buttons unless the radio is turned on.
    • Bill L.
      • April 1, 1985
      • 349
      Thanks Russ --- that is one of the subtle little things that I was afraid of with these radios--
      Thanks again
      Regards
      Bill
      • Frank D.
        • December 27, 2007
        • 2703
        They were never meant to pass judging; just to look somewhat like the original.
        I have one in my '63 and another in my '61; neither will pass judging...
        The C1 version is also missing the little red switch under the wonderbar "bar" for DX....
        • William F.
          • June 9, 2009
          • 1364
          Forget the radio. Just listen to the engine!
          • Bill L.
            • April 1, 1985
            • 349
            Holy cow --- I am already deaf in my right ear and I just bought a side pipe car !!! Might as well trash the left side too!!!!
            Still need the radio to work for the judges though ---
            Good point about the engine -----!!!!
            • Raymond R.
              • June 30, 1988
              • 115
              Not worried about judging. How does the one in the 63 perform?
              • Harry S.
                • July 31, 2002
                • 5330
                Read the speaker requirements very carefully!
                • Donald O.
                  • May 31, 1990
                  • 1591
                  Also look for max output at RMS rating and not peak, big difference in sound quality at a volume to hear at speed with side pipes. Do not try to use your original speaker either. I have a pair of Infinity 6" rounds on a plywood jackboard I made, even covered the board with black naugahyde. I am also using a single mount of a pair of 4" round Kenwood in the dash top in the OE place.
                  The radio unit is a Pioneer with 65watts rms that I bought from Corvette Central a long time ago and no longer offered. It doesn't have mp3, bluetooth, or any other modern inputs. It has a cassette, 3 FM bands (18 stations) and 1 AM band (6 stations).
                  Don't get anything from Custom Autosound, as in my opinon, they are worthless junk, radios & speakers.
                  DonO
                  • Gary R.
                    • April 1, 1989
                    • 1799
                    When I was building my 72 one of the few things I subbed out was the radio for an electronic upgrade to well recommended guy. Well I had to ship it back 3 times. Now once the new internals and speakers get power it sounds ok, not as good as I expected but ok. The problem is the volume pot is bad now. I think this was a common issue with these old radios, so if I turn it off it takes a bit of playing around to get it back on. ON/OFF several time, applying side load, and slowly turning on and VERY slowly turning up the volume. Then I don't turn it off and it's good until I hit a bump in the road!
                    I would have been better off having the radio restored vs updated or at least I expected all the parts to be checked out. That is what I do when I get a job in.
                    • Frank D.
                      • December 27, 2007
                      • 2703
                      It works just fine; I run it to the Custom Autosound 140W dual voice coil 6" x 9" single cone speaker...that is the ONLY one to use in the dash -- trust me on this. Here it is: http://www.classiccarstereos.com/pro...kers/3006.html
                      Here is the radio pictured with the speaker uninstalled; if you want to add bluetooth invisibly order the $60 worth of components shown from Crutchfield:
                      • Philip R.
                        • March 24, 2015
                        • 5
                        Has anyone used Joe's Classic Car Radio to repair their radios? Need my '67 radio repaired, but what to be able to pass NCRS judging.
                        Phil
