Need help on 73 BB wiring, - NCRS Discussion Boards
  • Lynn S.
    • November 1, 2004
    • 99
    Working on a 73 big block coup that was apart when I got the car. Car has a BB, AT, PS, PW, AC, and the air induction system in the hood. Missing (and not going to be replaced) is the AIR system, TCS solenoid(s), theft alarm, and seat belt warning
    wiring. I have a few wires left over and need help identifing (see attached pix). Appreciate any help. Lynn Schwebach
  • Lynn S.
    • November 1, 2004
    • 99
    Re: Need help on 73 BB wiring,
    Sorry folks, I forgot I had the bottom 4 attachments on this thread. But..........Now that I'm here could someone check my wire placement to be sure I'm good to go. The delay relay (whatever that is?) has an orange with black stripe wire coming from inside the car and a heavy red wire going to the horn relay. If you look at the last attachment the wires are as follows: 11:00 - Orange wire with 30 amp fuse from AC harness. 9:00 - heavy red wire from the delay relay. 7:00 - heavy red wire from the ignition harness. 5:00 - heavy red wire from the headlight harness. Thanks, Lynn Schwebach
    • Russ S.
      • April 30, 1982
      • 2162
      It all looks good to me comparing to my cars. Only difference I saw is that the red and orange on the F/W relay are reversed on my cars. I don't know if that makes any difference tho.
      • Harmon C.
        • August 31, 1994
        • 3228
        Tan and green plug is tcs soienoid lead. Single brown wire is carb. solenoid for idle shut off. Two orange plugs may belong under dash.
        Lyle
        • Lynn S.
          • November 1, 2004
          • 99
          Appreciate the help. I'll look inside for the orange plug connections. Lynn Schwebach
