Power brake booster for 1966 - NCRS Discussion Boards
  • Luis R.
    • August 31, 2002
    • 43
    I have a power brake booster 7011 for Corvette 1966 the part number is stamp in position 10 clock in the front and the dated is at 4 clock 297 in the front and the rear rivet is correct. I want to know if correct the dated at 4 clock?
  • Michael G.
    • January 1, 1997
    • 1251
    Re: Power brake booster for 1966
    Not sure what your asking Luis however the booster is dated the 297th day of '66.
    • Russ S.
      • April 30, 1982
      • 2163
      The date on my 66 booster is at 10:00 if that's what you are asking.
      • Luis R.
        • August 31, 2002
        • 43
        Yes my booster is at 4:00. Thanks Luis
        • Dave B.
          • April 30, 1984
          • 248
          I have a 7011 booster I picked up at Bloomington years ago with the 7011 in the 10 o'clock position, and Julian Date 113 at 4 o'clock. Both are readable from the front. I have been lead to believe that this configuration may not necessarily be correct for a '66.
          • John R.
            • November 1, 2005
            • 433
            Could someone post a photo of "rear rivet is correct"??
            • Luis R.
              • August 31, 2002
              • 43
              Hi John this is the rear rivet of my booster
              • John R.
                • November 1, 2005
                • 433
                Luis, thank you very much. I assume the repop boosters have a different type of rivet?
