63 regulator click when hooking battery wire to alternator - NCRS Discussion Boards
    • 6950
    Will the regulator click when hooking the red battery wire to back off alternator- Normal or not??
  • Domenic T.
    • January 29, 2010
    • 2452
    Re: 63 regulator click when hooking battery wire to alternator
    Ed,
    With engine not running, doesn't sound normal. I would guess the batt would drain.
    dom
    • Domenic T.
      • January 29, 2010
      • 2452
      Ed,
      Just thought of something. With the ignition on I believe it energizes the field. Could your key be on?
      DOM
        • 6950
        Dom, I believe the problem is in the alternator, I took apart to replace diodes with dated ones and fresh up Must have something grounded internally. I will take apart and recheck to find out why
        • Frank D.
          • December 27, 2007
          • 2703
          I will never hear it because I would not hook up that red wire with the battery connected...
