What grease/oil to use in 63 steering box - NCRS Discussion Boards
  • Chester C.
    • May 29, 2013
    • 154
    I tried the search and I'm sure it's there but cannot find. Question is, what type/brand/part number of grease/oil to use in a 1963 steering box. The liquid I removed from the steering box seems to be like a real thick oil but hard to tell if it's just old grease or oil.
  • Larry M.
    • January 1, 1992
    • 2688
    Re: What grease/oil to use in 63 steering box
    Chester:
    The steering box takes chassis lube. It requires a grease gun and a special adapter/fitting to add it to the box. You can either make one or buy from folks like Paragon. That is where I purchased mine. Price is $$. Fill instructions are included.
    The chassis lube I used is GM #12377985.
    If you take the box apart for rebuild/restoration, then most folks use a good quality synthetic chassis grease instead to repack everything during box re-assembly
    Larry
      • 43219
      Originally posted by Larry Mulder (20401)
      Chester:
      Larry
      Larry and Chester-------
      GM #12377985 is the lubricant I recommend. It is the "direct descendent" of the lubricant originally used and of GM #1052084. In fact, it's an improved formulation.
      Why did I picture a cartridge of the original lubricant? Well, it was easy for me to get at.
      • Larry M.
        • January 1, 1992
        • 2688
        [ATTACH=CONFIG]61259[/ATTACH][ATTACH=CONFIG]61260[/ATTACH][ATTACH=CONFIG]61261[/ATTACH]
        Joe:
        YOU are the one who gave me this part number years ago. It is the only lube I have used in my steering box. I was just passing it along to Chester.
        Larry
          • 15667
          I recommend a full synthetic NGLI #2 grease for wheel bearings, chassis joints, steering gear, headlight gearbox... just about every application that requires grease. Mobil 1 grease is good example and is commonly available at parts stores.
          • Chester C.
            • May 29, 2013
            • 154
            I've also used mobil 1 everywhere and I guess if it's good enough for the wheel bearings, it should be good enough for the steering box. My concern was, I did not know if it used an oil or grease. When I took the box apart, there was nothing but liquid in it. I guess over the years the grease broke down into a liquid state. Thanks for all replies
              • 43219
              Chester-------
              I highly doubt that the grease broke down into just an oil. Grease = an oil + a soap. The soap is not going to go away. More often, the oil component of the grease "goes away".
              Here's what I expect occurred: most other GM manual steering gear boxes of the period used a heavy weight gear oil. Some mechanics and steering box rebuilders think that ALL used this type of lubricant. They were/are wrong in the case of Corvettes. ALL 1953-82 Corvettes used the grease. So, I expect one of those misinformed have been in your steering gear in the past.
              • Gary R.
                • April 1, 1989
                • 1798
                Do not use Mobil 1 in a box, I have had several weep out the red oil from it. It doesn't take much heat to cause it to come out the seals or past sealed threads. Granted I used Mobil 1 grease in hundreds of vette boxes with only 3-4 leakers but 3-4 is too much. I switched over to Coastal bearing grease several years ago and haven't had one leak yet. I stopped using Mobil 1 on rear bearings, ball joints, rod ends for the same reason.
                Another good grease is Lucas Red & Tacky.
                More importantly is the condition of the gears and the proper setup of the box.
                • Domenic T.
                  • January 29, 2010
                  • 2452
                  When I restored my 67 I decided that everything would get a rebuild. When I rebuilt the steering box it was in great shape. Yes, when I added in the past I used gear lube. I didn't really notice before the rebuild if it leaked.
                  After I finished I thought I would use a good gear oil, after all it did have a rubber seal. Well It dripped, even past the seal so I thought I must have messed the seal up. Another seal and the same thing. I asked the TDB here and got the answer that was in my manual to begin with, grease. Now it does not drip.
                  Before all of that, I thought I would try to blow the gear oil out with air pressure and nothing. So I made a fitting and screwed it in the fill hole. Then I hooked the air to it and put a pan under the box to catch the gear oil. Not a drop came out, the 150 PSI actually made the seal work.
                  As soon as I removed the air the drip started again. Only about 5 drops a day but enough to make it look like there was bad work done.
                  Dom
                  • Domenic T.
                    • January 29, 2010
                    • 2452
                    Gary,
                    Just saw your post. You were the one that recommended the costal in my thread. All is good now after removing as much gear oil as I could and using the grease. I believe Costal is Auto Zone. There is still a bit of gear lube that I didn't get out and It finds it 's way past the grease, but only about a drip a week and I expect that to end.
                    Dom
                    • Gary R.
                      • April 1, 1989
                      • 1798
                      Dom
                      Many still think they need to use gear oil or a combination of gear oil and grease. It doesn't work. One of the leakers I had was on a bare frame sitting in the hot sun, the mobil 1 grease weeped out the lower seal and the lock nut.
                      I have not used the GM grease Joe recommends so I can't comment on it but the others I have and they work.
                      • Chester C.
                        • May 29, 2013
                        • 154
                        The Coastal/Uniplex high-temp grease (if that's the one you used) has an operating temperature of 325. The Mobil 1 is 302 temperature. The reason I pulled my box is it was leaking by way of the threads in the large nut. The seals were not leaking. Can not find a temp rating on the GM 12377985
                        • Gary R.
                          • April 1, 1989
                          • 1798
                          Yes that is the grease I have used the past 5-6 years
                            • 43219
                            Gary-----
                            Although I love synthetics and Mobil 1, I agree with you on the grease. I've had the same problem with it. It seems that the oil partially separates from the base.
                            I've not found that the GM #12377985 has this problem. It's also a good all-around chassis lubricant and replaced both the GM #1052497 and the GM #1052084 (the Corvette steering gear lubricant). It can even be used for Corvette rear wheel bearings but it's not what I use for those. For both front and rear wheel bearings I use either GM #1051344 or StaLube High Temperature Wheel Bearing Grease. I really like both of these. Absolutely no separation of oil and base and just wonderful lubricants. The 1051344 has been around forever and it's still among the best.
                              • 43219
                              Dom
                              Dom------
                              As I mentioned earlier, the misuse of about a 90 wt steering gear lube in Corvettes persisted for years among automotive service technicians and Corvette owners. It even extended to dealerships. In fact, for many years if you had gone to a Chevrolet dealership and asked for lubricant for your Corvette steering box, about 99% of the time you would have been sold GM #1052182. This was the about 90 wt oil that was specified for most other GM manual steering gears but not Corvette. I don't think it was ever used on 1953-62 Corvettes steering boxes and am absolutely certain it was never used on any 1963-82 Corvette steering box.
                              The myth still persists today:
