Engine Parts from Rebuild - NCRS Discussion Boards
  • Terry B.
    • August 31, 1999
    • 607
    I was spring cleaning my garage recently and ran across engine parts from a professional rebuild of my '68 original 427/390 hp that took place over 7 years ago. I have old pistons, crank shaft, valves, rods, oil pump and a few other things. Is there any reason to keep this stuff. I have not needed it in 7 years so should I pitch it or give back to the rebuilder? Thanks for your replies.
    Terry Buchanan
    Webmaster / Secretary - Heart of Ohio Chapter www.ncrs.org/hoo
    Corvettes Owned:
    1977 Coupe
    1968 Convertible 427/390 (L-36) Chapter Top Flight 2007, Regional Top Flight 2010, National Top Flight 2011
    2003 Electron Blue Coupe
    2019 Torch Red Grand Sport Coupe
  • Joe R.
    • May 31, 2006
    • 1822
    Re: Engine Parts from Rebuild
    Hi Terry,
    I could use the oil pump if it did not munch any metal.
    Joe
    • Michael F.
      • 745
      if you don't want offer up to members or others who might need somethings.
      Michael
      70 Mulsanne Blue LT-1
      03 Electron Blue Z06
      • Jim T.
        • March 1, 1993
        • 5351
        For sale adds for parts are very easy to enter for the NCRS Driveline. I would thing that the crankshaft could be sold.
          • 15706
          Used pistons aren't usually worth saving due to wear and no economincal way to refurb. them.
          What's wrong with the crankshaft and rods?
          Valves are reusable if stem wear is no more than half a mil and grinding leaves enough margin on the head.
          Oil pumps are reusable at least 90 percent of the time, but you can count on "professional" rebuilders replacing them 100 percent of the time, and of those at least half will have too much oil pressure.
          • Jim H.
            • December 15, 2006
            • 146
            When polished, the piston heads make excellent desk paper weights.
              • 43277
              Terry------
              What sort of crankshaft and connecting rods did the engine builder use in the rebuild? Big $$$$ specialty aftermarket parts or just remanufactured original-type parts? If the latter, your original parts could probably have been similarly rebuilt.
              If an engine has been well cared for (e.g. regular oil changes), crankshafts are almost always re-usable without any journal grinding----just polishing. I'd much rather have an original standard journal size crankshaft than a remanufactured unit that will virtually always be ground undersize, sometimes as much as .030".
              • Terry B.
                • August 31, 1999
                • 607
                All,
                I miss spoke about the crankshaft, it was reused. It is the cam shaft that I have in my boxes of stuff. (big difference)
                It sounds like, from the people who responded, that I should hang on to a few of these items and discard the rest.
                Terry Buchanan
                Corvettes Owned:
                1977 Coupe
                  • 15706
                  You can measure the heel to toe dimension of the cam lobes, and if it's only worn a few thou it may be reusable, IF you marked the lifters to which lobe they mated to and the lifter faces are not significantly worn. If not, it's all junk.
                    Aluminum nitro rods, twisted 90* or so, with a matching piston, make nice desk clocks.
