Gaskets - NCRS Discussion Boards
Gaskets
  • Ralph P.
    • February 1, 1990
    • 253
    Gaskets
    I'm ready to replace gaskets on my RC15 radiator cap ( rubber), oil cap( fiber), and, gas cap(paper) . How do you get these stretched to fit without tearing or cutting
  • Bill L.
    • April 1, 1985
    • 349
    Re: Gaskets
    I don't know about the radiator and oil cap but I used a a pair of dividers to measure the gas cap gasket on my car. I then used a compass (set to match the divider measurements) to lay out two concentric circles on a piece of heavy weight brown card stock that I had --- I then carefully cut the gasket out of the card stock with an exact-o knife and #11 blade. If you measure correctly the gasket should be a press fit. Accuracy counts as the card stock is not going to stretch (obviously). Pretty cheap, fast and easy --- and it judges out just fine.
    Regards
    Bill
      • 43246
      Re: Gaskets
      Regards
      Bill
      Bill and Ralph-------
      The fuel cap gasket can be replaced as described. However, I don't know of any way to replace the radiator cap and oil fill cap (valve cover type) without disassembling the caps. That presents a significant problem because the cap has to be re-riveted to reassemble it.
      • Ralph P.
        • February 1, 1990
        • 253
        Re: Gaskets
        Thanks, Guys..... I thought there was a method explained in a past thread, but, haven't had any success . Guess I'll hope someone has done this....
        • Bill L.
          • April 1, 1985
          • 349
          Re: Gaskets
          I agree with Joe --- you might try Pete Lindahl in the NM Chapter --- he does some very nice work with radiator and over flow caps ---
          Pete Lindahl (505-663-0995 or plindahl@comcast.net
          Regards
          Bill
          Regards
          Bill
