Hi all,
I picked up some bendix Wheel cylinders to begin installing my drum brakes on the 64. They come with poly dust seals on each end which is what I am accustomed to seeing on drum brakes, but there is a bracket on the rear mounting plate which interferes with the poly seal. If I remove the dust seal the casting fits snugly between the bracket. Is it correct to install without the dust seal? Or do I have the wrong wheel cylinder?
