Gas tank fuel sender - NCRS Discussion Boards
  • Jack J.
    • July 31, 2000
    • 640
    Attention Joe Lucia: Joe what application is this sender for-P/N 6425827 ? It sure doesn't look like the original one from my 64. Thanks in advance. Jack J.
  • Edward B.
    • March 29, 2013
    • 691
    Re: Gas tank fuel sender
    Jack, I'm not Joe, but the 6425827 was superseded by the 6428065 in October of 1968, and the 6428065 is shown in my October, 1972 P&A 30B as being used on the 63-67 (except 36 gallon tank), and 65-67 (except 37.5 gallon tank). Maybe someone with a late 1967 or early 1968 P&A can verify this for you.
    Ed
      • 43221
      Jack-------
      The GM #6425827 was used in PRODUCTION and once available in SERVICE for 1965-67 Corvettes. It was also SERVICE for 1963-64 Corvettes for several years.
      • Mike T.
        • January 1, 1992
        • 568
        Jack - How 'different' is the sending unit from your '64 to the one I have in my relatively early VIN, 4212, 65 Coupe?
        Mike T. - Prescott AZ.
        • Joe R.
          • July 31, 1976
          • 4551
          Guys,
          Here is a pic of an NOS 6425827 and an original from a 1964.
          There IS no difference in the design but small differences in wiring and connectors.
          Both work the same and read accurately.
            • 43221
            Originally posted by Joe Ray (1011)
            Guys,
            JR[ATTACH=CONFIG]61158[/ATTACH][ATTACH=CONFIG]61159[/ATTACH]
            Joe-------
            The thing I don't understand about this is that the 6425827 was discontinued and superceded in 1968. So, I don't understand how any NOS example of the 6425827 could have a parts tag with a bar code on it as the one you pictured.
            • Joe R.
              • July 31, 1976
              • 4551
              Well Joe, there it is!!! Would you be convinced if I send you a pic of the box????
              JR
                • 43221
                JR
                JR-------
                I didn't say I was not convinced, I just said that I did not understand it. Apparently, the old part number was somehow "brought back" but I cannot figure out why.
