Rivet Set Tool - NCRS Discussion Boards
Rivet Set Tool
  • Harry S.
    • July 31, 2002
    • 5342
    Rivet Set Tool
    I'm restoring my battery access panel. I have the kit with the 6 threaded inserts and the 12 solid flat head aluminum rivets. The rivets are 5/16 long (.3125) and 3/32 in diameter.
    I have the bucking bar but I need a smaller river-set. I'm doing this by hand.
    I've searched several places for a rivet-set for the 3/32 in diameter rivet without any luck. Any leads would be helpful or if anyone has one that I could borrow that would be great.
  • Domenic T.
    • January 29, 2010
    • 2452
    Re: Rivet Set Tool
    Harry,
    Google up Aircraft Spruce. They have them for under 10 bucks. I would give them a call because it's easy to get the wrong one. Also ther are less expensive ones, and expensive ones. The cheaper work great and I can't tell the difference. There are also different rivet heads to choose from. Flat, round, and one that is less round, (oval).
    Dom
    • Joe R.
      • July 31, 1976
      • 4552
      Re: Rivet Set Tool
      Harry,
      I use Jay-Cee Sales & Rivet Inc. 1 800 521-6777
      Ask for Andy Harmon Ext. # 17
      JR
      • Larry M.
        • January 1, 1992
        • 2701
        Re: Rivet Set Tool
        I planned to just make one out of a piece of 6 inch long round stock when the time came for me to do this job. Probably 3/8 inch diameter round stock. Drill a small dimple/recess in one end to help form the rivet end.
        There are various "small rivet install kits" available from a few Corvette vendors, but the contacts DOM and Joe Ray provided should also,work well.
        Larry
        • Harry S.
          • July 31, 2002
          • 5342
          Re: Rivet Set Tool
          Thank all, I'll contact them.
          • Tracy C.
            • July 31, 2003
            • 2739
            Re: Rivet Set Tool
            Or you could surf eBay for a deal... Just search "rivet set" Usually you can buy a lot of several used for the same money. Here are some new ones with the 3/32 universal head included.
            tc
