Penske timing light (Schematic diagram needed) - NCRS Discussion Boards
  • Richard S.
    • April 1, 2003
    • 288
    Can someone provide me a schematic diagram for a Penske timing light model 244.2115? This light was sold by Sears. If possible a matching parts list.
  • Larry M.
    • January 1, 1992
    • 2688
    Re: Penske timing light (Schematic diagram needed)
    Is this what you want??
    I simply went to Sears Parts and typed in your part number.
    A lot of used ones on Ebay (for parts or whole)
    Larry
    EDIT: More info for you. http://forums.aaca.org/topic/68849-timing-light/
    • Richard S.
      • April 1, 2003
      • 288
      Larry
      Thanks Larry, I did see that schematic but no parts list included and view not clear.
      Rich
      • Frank K.
        • January 1, 2000
        • 319
        I have that timing lite and a sun model also. I don't have the parts list for the sears but the sun I have! There is very little parts to be bought. You can contact Sears&Roebuck on line I believe there is an avenue you can take for parts. If you live in greator Hartford ct area you can borrow mine
        • Larry M.
          • January 1, 1992
          • 2688
          The Sears Parts List was next to the schematic drawing I provided. Perhaps a click or two of the mouse or trackball was needed to bring it up. You are correct, there were only a few parts available for this timing light: a few nuts, bolts, and screws, and a few resistors and diodes.
          The second link I provided had the part number for a compatible flash tube from an Actron light that others have used/substituted.
          Ebay is also full of similar lights for a few $……either for parts or for full use.
          This is a very nice timing light that I had personally used for over 30 years myself, but switched to an Actron "dial-back" years ago. I gave my old Penske light away to another.
          Larry
          • William F.
            • June 9, 2009
            • 1363
            Just buy a new digital dial back light that also gives rpm-some give dwell also. Not that expensive and you'll find it much more useful than your old broken one.
            • Richard S.
              • April 1, 2003
              • 288
              Larry
              I did notice the abbreviated part list but I was hoping that a more detailed list might be available that shows the capacitor detail including the voltage rating. One particular capacitor such as what I believe is labeled C4 across the tube and 100K resistor.
              Rich
              • Richard S.
                • April 1, 2003
                • 288
                Frank
                Thanks for the offer to use your light but I am a bit to far away. I will do a little searching first to see if I can find the necessary parts to fix the light.
                Rich
                • Richard S.
                  • April 1, 2003
                  • 288
                  William
                  Thanks but,
                  Before I resort to the new timing light I want to explore possible repair path. I would like to say with the old light it goes well with my old vett and old owner.
                  Rich
                  • Joe R.
                    • May 31, 2006
                    • 1822
                    Rich,
                    Can you take it apart and take a look at the capacitor? It should say what the voltage rating is. Are you sure the capacitor is bad?
                    Joe
                    • Richard S.
                      • April 1, 2003
                      • 288
                      Yes the cap is defective. There is no identification as to capacity or voltage rating on the cap just a part number that I can not reference anywhere. It is a large paper style located in the light handle.
                      Rich
                      • Joe R.
                        • May 31, 2006
                        • 1822
                        Rich,
                        Well, I guess nothing is ever easy! What is the part number?
                        Joe
                        • Richard S.
                          • April 1, 2003
                          • 288
                          Part # T.L.2208-1
                          Rich
