As I posted in my thread about questions on the subject, we have the L-89 up and running now.with the new carbs after a battle with the usual Holley leak gremlins. On subsequent test drives we've noticed a habit of the rear carb wanting to hang open just a bit. By a bit I mean an additional 500 RPM at idle. One can pop it back to normal by pushing on the safety linkage on the driver's side by hand, or goose it a few times which sometimes does the same thing. We noticed a sticking condition before installing the rear carb and tore down the vacuum diaphragm linkage. By re-positioning the diaphragm and return spring it seemed we had corrected the problem, but I guess not completely.
Has anyone else had a similar problem with a rear carb, as on the tri-power, or even with a 4 barrel Holley equipped with a vacuum operated secondary throttle??
Stu Fox
Stu Fox
