1970 Wiper Motor 3 Port Washer ? 5044758 - NCRS Discussion Boards
  • William H.
    • January 1, 2006
    • 209
    I have what I think is my original wiper motor on my 1970 with the correct part number 5044758 and date code (13 0 2A) but it has 3 ports. I guess it's possible that the port was changed out but has anyone seen this deviation? Thanks for any observations.
    Bill Hyndman
    The 'Sound of Freedom' if not a UH-60 Blackhawk, then it must be a Corvette!
    1962 Big Brake Fuelie
    1965 Fuelie Convertible
    1968 L89 Convertible
  • Russ S.
    • April 30, 1982
    • 2162
    Re: 1970 Wiper Motor 3 Port Washer ? 5044758
    I see at least one hose that originally went to the five port.
      • 43221
      [ATTACH=CONFIG]60997[/ATTACH][ATTACH=CONFIG]60998[/ATTACH]
      Bill------
      Assuming that any were ever made with 3 port, they would have had a different part number than the 5044758 which was the PRODUCTION part number for the motor equipped with a 5 port pump.
      Much more likely, the original pump was replaced with a 3 port pump which was available in SERVICE long after the 5 port went away.
      • Mike E.
        • February 28, 1975
        • 5138
        Do you have washer nozzles on your headlight bezels? Are there extra hoses under your headlights (that would have attached to nozzles)? I agree with previous posters that your 5-port has been replaced, and suggest you look at the items that I mentioned to help convince yourself of that.
        • William H.
          • January 1, 2006
          • 209
          Thanks for the insights. It was definitely a 5 port that was replaced by a 3. My mystery solved....... Much appreciated.
          Bill Hyndman
