C2 Ball Joint and judging - NCRS Discussion Boards
  • Donald H.
    • November 2, 2009
    • 2586
    I am using near NOS upper ball joints and plan to rivet them in as original.
    For my lowers, I purchased AC Delco "assembled in the USA" from RockAuto. These will not pass muster as for as the lower shaft/taper without threads.
    My question is, should I go ahead and rivet the lowers? Will that save me any deducts, or since they are not configured as originals am I wasting my time to rivet them?
    Don
    Don Harris
    Former: 60 Red/Red, 2x4, 245hp (Regional and National Top Flight 2013), 66 coupe Nassau Blue, L79 (Chapter and Regional Top Flight 2017)
  • Keith B.
    • September 15, 2014
    • 1588
    Re: C2 Ball Joint and judging
    Rivet them. Under CDCIF format you need the I for installation to be correct
      • 6948
      Don, Keith is correct , and make sure the Rivets and facing the right direction. take a pic with the I-PHONE or camera. Under the CDCIF the dedect would only be a configuration, about 1 point small compared to NOS lowers prices for the lowers,
      • Donald H.
        • November 2, 2009
        • 2586
        OK, thanks.
        I removed old rivets from the uppers and lowers.
        As far as I can tell, the lowers had the head on the inside and was set/crushed on the outside. Whatever St. Louis used produced a nice rounded end.
        Don
        Don Harris
