I've been driving my Triple Crown winning '59 a lot more lately and a problem has come up. It's not a BIG problem but it's noticeable. It's a bone stock 270hp 283 with the typical Duntov cam, 2613 & 14 carbs rebuilt by Jerry Katter and an 891 centrifugal advance distributor recently degreed at 600 rpm at 0 degrees and 3700 rpm at 28 degrees total. When I'm cruising down the highway at constant throttle it "pops" out the exhaust about every 1/2 to 1 mile. Not multiple times...but only once. When I really get on it and then decelerate from about 5000 rpm....I hear the exhaust pop back about two or three times.
The car has about 1000 miles on it. Everything else is kosher....It starts consistently well even when hot and the carbs don't drip. There is a slight "fog" over the primary's however after stopping and both exhausts are burning slightly blackish. I'm running AC 45's and they need cleaning out occasionally. I'm thinking the carbs are dumping a little raw fuel into the exhausts.....What should be my plan of attack?
