Distributor Recurve Service - NCRS Discussion Boards
  • Patrick B.
    • November 1, 2000
    • 5
    Can someone make a solid recommendation to recurve my LS-5 distributor to factory specs? Appreciate any suggestions for guys who specialize in our cars. Thanks much! Pat
  • Frank D.
    • December 27, 2007
    • 2703
    Re: Distributor Recurve Service
    Lars Grimsrud
    (303) 323-5745
    lars.grimsrud@lmco.com
    He just did my '63 distributor two months ago. Fast turn around, reasonably priced and very good at what he does !
      • 11653
      Bill Clupper. He's available through contact info here on the board.
        • 15697
        Assuming it's set up with a more performance oriented spark advance map, why would you want to go back to OE specs? The OE centrifugal curve is too short and lazy, and the VAC is lazy and set up ported. The map is set up for emission control, not performance or fuel economy.
        About 30 centrifugal all in by 3000-3500, 8-10 initial and a B26 VAC set up for full time vacuum advance would be pretty close to ideal.
        • Frank D.
          • December 27, 2007
          • 2703
          Very true. The stock curve is very conservative. After I got my distributor back from Lars I now have my initial timing at 16* on my stock 250hp '63 coupe...way above specs.
          The car has much snappier response and no bad effects on economy and idles like a dream.
          • Timothy B.
            • April 30, 1983
            • 5192
            Frank, so you are running approx 30* idle timing with the V/A connected?
            • Mike F.
              • April 25, 2011
              • 668
              You may want to print these out, good reading.
              http://www.lbfun.com/warehouse/tech_...101Article.pdf
              http://www.lbfun.com/warehouse/tech_..._explained.pdf
              http://www.lbfun.com/warehouse/tech_...ance_Specs.pdf
              http://www.lbfun.com/warehouse/tech_...t%20Timing.pdf
              • Frank D.
                • December 27, 2007
                • 2703
                Prob close - haven't measured it with vac advance attached. This is my curve after Lars was done with my distributor.
                • Donald A.
                  • January 7, 2013
                  • 239
                  Lars did my LS-5 to perfection!!!
